Can i conver a an old mig to a wire feeder?
Here are my thoghts get a mig suchas a hobart handler(or similerly sized mig from ther copany) remove the coils and transformer and anything else that converts the power from the wall to welding curent. Then conect it to a constant voltage output (engine drive set for CV).
Results 1 to 10 of 10
Thread: convert old mig to wire feeder
10-02-2008, 04:46 PM #1
- Sep 2008
- southwestern ohio
- 272
10-02-2008, 04:55 PM #2
Member
- Aug 2008
- Phelps, NY
- 70
I bet it could be done but I question what benefit you will see. I would look for an older wire feed to match with the machine you have now. I don't think you will save any money by hacking a small MIG unless you have it on hand and a standalone feeder will likely be better made and last longer than the components in a HH wire feed.
What CV machine do you have?
10-02-2008, 05:00 PM #3
Member
- Aug 2008
- Phelps, NY
- 70
Another thing to consider is that even if you did modify a HH you would need to start with a machine the same size as the power source you'll be using. You can't use a HH130 wire feed on a 300A engine driven welder as it can't handle the current.
10-04-2008, 02:33 AM #4
- Aug 2008
- Krefeld, Germany
- 18
Of course you can. But you'll have to know the limitations or you'll fry the little feeder.
Nothing wrong with using a small gun on a large machine for tight space / low power jobs. Or do you think that all those small, but high quality guns are only made for upgrading Harbor Freight welders?
Nevertheless, a real feeder unit is way stronger and you would usually have a quick disconnect for different guns.
Steffen
Krefeld, Germany
10-04-2008, 11:39 AM #5
You need a drive mechanism intended for constant current to run it off a stick power supply like your mobile rig. Just gutting a mig machine is only part of the problem. The wire speed rate will be determined by the arc length, and without a robot welding for you, that length will vary with your every move.
Keep an eye on CL and ebay. I just sold a 24' Push-Pull Hobart suitcase feeder with both CC and CV capabilities (perfect for what you want) - it went for $260 delivered. I bought a brand new Airco feeder for $130 delivered about 6 months ago. The deals are out there, but you need to be looking for them.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
10-04-2008, 11:41 AM #6
Can I ask really strange and obscurer questions.
Can I remove the engine from my car and replace it with a steam plant and electric motors and then put it in the garden.
If I walk to work and you eat pie will the Jets win the World S
eries.
Yes Mr. Melter you can as long as it is legal in your area you can do anything you wish.
Good luck
10-04-2008, 09:09 PM #7
Do these engine drives not have AUX power?
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
10-04-2008, 10:25 PM #8
I think the issue is that he's already got the welding power supply, and just wants to add GMAW capability to it rather than having to buy another full welder just to use his engine drive as a gen set.
The problem is that a decent suitcase CV/CC feeder is going to cost as much as a whole MM212 new. Used they fetch a good premium as well, but if there's an oddball out there, you can do pretty good.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
10-04-2008, 11:21 PM #9
- Feb 2004
- 1,161
10-05-2008, 12:00 AM #10
- Feb 2005
- N.E. SD
- 1,366
And, since he has CV capabilities, he can buy almost any old wire feed on Ebay and cable it up and run it.
I have two old Miller 30A feeders that still push wire.Jeff
