Results 11 to 20 of 20
    2,634
    Quote Originally Posted by jpmassey View Post
    I sanded and then SS wire brushed it. The edges are plasma cut, so that probably didn't help.
    "Plasma Arc Cutting, Beveling, and Gouging:
    · This process has some limitations and must be carefully controlled. If it is used, it requires the power source to be set (DCEN) along with the use of small orifices to gain high velocity and concentrated heat. Heat affected zones will be crack prone particularly for 2XXX, 6XXX, and 7XXX series alloys and will require 1/8 inch or more of mechanical surface removal before welding. Series 1XXX, 3XXX, and 5XXX alloys are not as crack prone and can generally be welded as cut by this process."
    From the Link
    Feb 2008
    flat , and lots of dirt
    123
    Default roger that
    I was gonna say that too. Unless you are using a shielding gas while plasma cutting, you have to remove most of the HAZ because of the high levels of oxidization that occur. Even when you use shielding gas vs. comp air, the oxidization penetrates more than you would think. Also, I would use a 5356 filler on a 50xx series aluminum. It also looks like you might need to use a little more balance to clean the weld better.
    What machine are you using? What tungsten? Balled or pointed? Pulse?
    SYNCROWAVE 200
    Atlas 618 lathe (vintage 1960) reconditioned DC
    Sioux 3/8 Pneumatic Reversible Drill
    Makita Everything else
    2400 square feet of Sanford and Son lookin shop space
    "Once the spoon flys, putting the pin back in won't solve anything"
    USA 15T, 15V
    www.myspace.com/blackbird455
    http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
    Aug 2008
    24
    Quote Originally Posted by Blackbird455 View Post
    Syncrowave 250dx
    I believe I was using pointed 2% thoriated.
    No pulse option.
    Mar 2008
    Anchorage AK
    344
    Quote Originally Posted by griff01 View Post
    The picture appears to have very little filler and a bunch of contamination.
    Griff
    Where?
    1234567890
    Feb 2008
    123
    Default Uhh....
    See it now?
    The little black pepper looking flakes that float on the top of the puddle turn into stuff that looks like that. Also notice that the white "flash" on the outside of the bead is narrow, meaning only a small amount of DCEN in the cycle, balance adjustment might fix it, but like was said before, if it was plasma cut, there is alot of oxide present, and it needs to be removed before welding.
    SYNCROWAVE 200
    USA 15T, 15V
    Oklahoma
    641
    Quote Originally Posted by FATFAB View Post
    Where?
    1234567890
    Open eyes, look in picture.
    Griff
    Oklahoma
    641
    See it now?
    Thanks for the back-up there blackbird.
    Griff
    Oklahoma
    641
    Smile
    Hmmm....I might be watching for enough penetration. This is my 1st major AL welding project, so I was excited just not to blow a 1/2" hole in it.
    I didn't think that preheating was required on such thin material?
    Pre-heat is not required if you have enough machine.
    "Hot cracking" ( that is what this crack is) is influenced by only three things:
    1. base alloy chemistry
    2. filler alloy
    3. joint design
    1 and 2 are self explanatory. 3 also includes amount of filler put into the joint.
    Griff
    Oklahoma
    641
    Smile
    Syncrowave 250dx
    No pulse option.
    I just saw where you have a SyncroWave 250. That is plenty of machine for .125 and no pre-heat.
    5356 is the "correct" filler for the 5052 base but the 4043 "should" have been ok due to its higher silicon content. That is out of the "book" .
    Griff
    Noth Dakota
    505
    Looks like more filler is needed to offset the undercut.
