Page 1 of 10 123456 ... LastLast
Results 1 to 10 of 92
    Nov 2007
    136
    Default Evolution Cold saw
    I'm thinking about getting an Evolution Rage 2 cold saw... What do you all think
    http://www.evolutiononlineshop.com/s...%202%20%20Saw/
    250.00 at Airgas with a general purpase blade
    MM 175 W/ Spoolgun
    Syncrowave 200
    Maxstar 200 dx (BROKE)
    Portable Victor O/A
    Palmgren Bench Drill Press
    14" Evolution Dry Saw
    IR 60 Gal. 3 HP Compressor
    Speedglas 9100x
    My Brain
    alabama
    717
    Not technically a cold saw.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    Sep 2006
    Wichita Falls, Tx
    177
    the rage 2 is an old saw, I would get the newer rage 3 if I was going to buy evolution brand saw.( but I think these saws are cheaper made and for a little more you can get alot better quality)
    But if I was going to buy a dry cut saw, my first choice would be the 12" makita (it is the sturdest made, best design, and heavy duty) the only draw back is the 12" blade but is is better made. and If I had to have the 14" blade them I would get the Milwaukee (it is still a very good saw, just the makita has a little better vise and handle) . But stay away from the dewalt multicutter. It is cheap made and is a POS.
    The blade on the makita is the best.
    Crete Illinois
    186
    I've got an Eviolution Raptor and lemme tell yuh It works awesome ........using it to cut square tubing and it goes through almost like butter..........I've heard a ton of pros & cons about these saws but from my experience it works awesome.. Just my 2cents Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    JD2 Tubing bender with Hydraulic conversion
    Evolution Raptor15" SteelDry Cut Saw
    Hypertherm Powermax 30
    Some really cool hammers BIG and small
    Raymore Missouri
    1,907
    Quote Originally Posted by ace4059 View Post
    Why do you call the Dewalt a POS. I have one and it seems to work fine.
    What do you base your statement on?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Sep 2006
    Wichita Falls, Tx
    177
    It is very cheap built. The base is stamped steel not the heavy cast. The guard is plastic and the motor is over rated and needs to be built better. the swivel vise needs to tighten up better because it you are cutting and the piece gets loose then, you will be sweeping up broken teeth. The blade is also not the best, but it works ok. On the dewalt and milwaukee, the blades are for cutting metal but the design (teeth shape) is based on a regular blade. Look and the design of the makita blades and the freud diablo blades. They are better designed and will last longer.
    Yes all these saws will work but from all the research that I have done, comparisons, use, and demos that I have seen, the makita is my first choice, followed by the milwaukee.
    Oct 2005
    Bulverde, Tx
    1,244
    Strange...my DeWalt has been flawless except for operator error for the last several years. I would say my 10,000 or so cuts would disagree with your research. Could it be better? Yes. Is it a POS? **** NO.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Sep 2006
    Wichita Falls, Tx
    177
    let me know when it craps out.
    Nov 2007
    136
    Are you guys done?
    What I like about the evolution is that is spins at 1400 rpm instead of 3 or 4 thousand.. and I like the idea of cutting metal rather than grinding metal.
    Does anyone here have a saw by Evolution?
    Later
    MM 175 W/ Spoolgun
    Syncrowave 200
    Portable Victor O/A
    Speedglas 9100x
    My Brain
    Sep 2006
    Wichita Falls, Tx
    177
    Quote Originally Posted by benny365 View Post
    Later
    No sorry but I dont know anyone with the evolution saw.
    huh, thats funny, because we are talking about the same saw, only the makita spins at 1200 rpms and the dewalt 1300 rpms and milwaukee spin at 1500rpms.
    Are you guys done?
    I guess. You wanted to know about a dry cut saw (not a cold saw) and I told you which one is supieor so you wouldnt make a mistake and buy an inferior product. But then again, dont listen to what I have to say becasue I must not know what the **** I am talking about and the hours of research means nothing. I am not here to push a brand, only the better saw.
    One example of this is I have 13 angle grinders. All dewalt. A friend has milwaukee angle grinders, and brought one over for me to use. I can tell you that the milwaukee is made better than my dewalts and the next ones I buy might be milwaukee. From all the articles and threads that I have read, Metabo is the best angle grinder (And when my dewalts crap out I am going to try a metabo and see how I like it compaired to milwaukee). So if some one wants to know about an angle grinder, Ill inform them that I personally think from what I have read that the metabo is the best one for the money.
    Honestly I could care less which one you buy, Its your money.
    Edit Here is an email from Alan at tricktools (van santent) Ryan, thanks for your email. Evolution just recently introduced the RAGE and FURY lines of equipment. The 380 Raptor is part of the high-end STEEL line of machines which offer a 5 yr warranty, and are industrial rated. They have a 2200 watt motor. The RAGE is a 2000 watt motor with a 3 year warranty. The RAGE is considered more of a multi-purpose saw.
    The Jancy units are comparable to the Evolution STEEL series, they are the industrial versions. Mostly just brand name preference as you mentioned!
    Alan Geetings
    Sales Manager
    Van Sant Enterprises, Inc.
    641-628-3860 ext 108
    www.tricktools.com"
    Also if you watch the youtube videos of the rage 2 it show it is a multi purpose saw cutting wood with metal nails in it.
