    frankee_one Guest
    Default Weld thickness???
    How do you measure a weld thickmess? From the center of weld... or edge to edge?
    Jun 2006
    Calgary, Alberta
    377
    Weld thickness is measured by both the leg legnth and the throat. A fillet weld has two legs with toes and a throat, a groove weld has a throat, toes, root reinforcement, and face reinfocement. A typical fillet weld will have a leg length equal to the base metals thickness and a throat that runs from the root and intercepts a line drawn from toe to toe. A concave surface between two toes (or edges) of a fillet weld can offer insufficient throat. A slightly convex surface offers sufficient throat and a little more, but too much is a waste of filler.
    Fillet guages are available from most local welding supply stores and are a good tool for measuring welds.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    wow, thats prity well put. i was just going to say it depends on the weld type called out in the prints. but his is much better.
    Ocean City, Maryland
    951
    Thumbs up
    Wow, that was an awesome explanation johnnytig , Thanks
    Scott
    HMW [Heavy Metal welding]
    Oahu, Hawaii
    2,469
    SHOWOFF Just more crap I need to remember
    I'm not late...
    I'm just on Hawaiian Time
