Results 1 to 10 of 10
    Sep 2008
    Raleigh, NC
    6
    Default Crankshaft Fab table
    Wanted to pass along an idea I cooked up. I bought a junked 302 motor to build a conference table out of and came upon a slew of parts to recycle. As I stared at the parts, I thought about making them more shop useful instead of recycling in normal scrap yard terms.
    I grabbed what I could for a balanced weight at the bottom and added the crankshaft as my main section. It had a great natural balance and I added a 10 inch section of pipe to the top of the crank for a custom fit to my height. Welding the 1/8" thick pipe was quite tricky to the cast crankshaft but it worked out great. I also added some support underneath through 1" solid steel tubing to support the 1/2" plate at the top.
    The mini fab table can hold a great deal of weight and is easy to navigate around. My intentions for it were to work on motorcycle frames, possible grind stand or to place a shotbag on and pound out sheet metal. Quite happy with it overall and will be building another one soon.
    also used 2 carpet samples at the base to muffle any banging, wabbling or scraping on the concrete floor.
    Last edited by Rusty Knuckles; 09-24-2008 at 12:25 PM. Reason: checking the images
    Sep 2008
    Omaha, NE
    447
    Sounds cool, but your pictures aren't working
    can't wait to check it out.
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Sep 2008
    Raleigh, NC
    6
    Default Table images
    hopefully this works. First post, so I am trying to figure out how to post the images correctly
    Sep 2008
    Raleigh, NC
    6
    Default Ok, all else failed try this:
    Sep 2008
    Omaha, NE
    447
    Looks good, are those some auto tranny parts on the base as well? Looks like part of the fluid pump, but maybe that's just the pics as i didn't see a mention of it in your first post.
    Hobart Handler 135
    Lathe/Mill/Bandsaw
    Sep 2008
    Raleigh, NC
    6
    I was digging around and grabbed the harmonic balancer and the fly wheel. Added some more scrap steel under the base as well.
    2,636
    2,636
    Like the Ducati Painting- are you an Illustrator by trade?
    Sep 2008
    Raleigh, NC
    6
    I guess I could call myself an illustrator by trade. I work in many facets of design/marketing/communications and just seem to have had a pencil stuck to my hand since birth.
    here is my day to day business site:
    http://ralfinoe.com/
    design work pays the bills so I can build bikes on the side.
    Sep 2008
    Raleigh, NC
    6
    thanks for posting the images as well, I appreciate it!
