    Feb 2006
    Default south texas bump gate
    can anyone help me with a drawing,picture,idea etc how to build a bump gate.you just push it with your bumper and it open allowing enough time to drive in and it closes behind you. thanks
    Feb 2006
    Oviedo Fl.
    26
    Default bump gate
    I don't have pics but I made one years ago used shocks off a ford hachback
    from the junk yard 3 on each side from what I can recall."worked pritty good"
    hope this helps you out.
    Feb 2006
    Oviedo Fl.
    26
    by the way I did have to lengthin the bars about 4' on each one the gate was a
    two peace deal open from the center.Used old tires so I did not damg.the gate
    Good luck
    tiny-turbo Guest
    Default bump gate
    The only place i have seen those gates is on the kleberg and Kennedy county ranches. They showed one on Tv when they were reporting on the vice pres hunting accident.
    If you have access to The Prairie Farm Report TV show they have shown quite a few of these. They also have a video at www.farmvideos.com that shows these and other farm related inventions.
    Amos F
    Feb 2006
    do you have any idea what videos show these bump gates
    Fencing and gates video shows a couple of these I believe. If you call them they can tell you how many gates like this there are. I don't know what the price of the videos is though. They used to be quite expensive. My brother in law used to tape the show for me and send me the tapes before satelite TV existed because the show was only a western Canada production. I ordered one inventions video bach in the early 90's and I thought it was expensive then.
    Amos F
    Laredo,Tx
    16
    Default bump gates
    Hi everybody,Here are some drawings of a bumping gate.I hope you can
    understand them, I'am not very good at drawing.
    I have seen quite a few of them and this is the way they look.
    The trick is on the cable or chain you use.It puts tension on it.
    When you bump it and drive thru the chain will bring it back.
    On the center of the gate you can put oakwood or treated wood that way
    you wont damage your vehicle.
    South of your idea of South Texas
    8
    Default Bump gate plans
    What part are you unsure of ? Where is this going to be built in shop then transported or on site and erected in place. I'v seen many ideas work just get ready for some heavy lifting. And remember this is one place that the use of thin wall pipe is not recomended due to twisting and bending over time.
