Not quite a welding project but not sure where to post it. I need to remove paint from quite a few small to mid size aluminium parts. I have tried beadblasting but that takes time. I have thought about this
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
As you can see, the cost is up there. Anyone have any experience with something like this? Homemade units? I have been told that a tumbler will beat the parts up too bad. Help or input appreciated. Thanks.
Results 1 to 10 of 20
Thread: Vibratory tumbler question
Hybrid View
09-21-2008, 08:15 PM #1
- Sep 2008
- 9
09-21-2008, 08:21 PM #2
- Sep 2002
- Clark County, NV
- 2,696
I have a large Dillon model. Never tried a media designed for removing paint.
Works great at polishing brass, though.
09-22-2008, 10:04 AM #3
09-22-2008, 03:11 PM #4
- Sep 2002
- Clark County, NV
- 2,696
09-22-2008, 03:19 PM #5
Could you put the parts in a chemical stripper?
Tim Beeker,
T-N-J Industries
(my side bussiness)
Esab 450i with wire feeder
HH135 mig
Miller aircrafter 330 - sold
Marathon 315mm coldsaw
table saw
Dewalt cut off saw
Sand blast cabinet
lots of hand grinders
Harris torch
beer fridge
09-22-2008, 09:45 PM #6
- Sep 2008
- 9
The parts will be painted after being cleaned so a polished finish is not needed or desirable. I have thought about trying a cement mixer as mentioned but most I have seen have paddles which I think may beat the stuff up. Can anyone recommed a chemical stripper. The parts are from snowplow pumps. Can I dip in a bucket in a bucket and hose off? My past experience with stripper hasn't been enjoyable. I have limited space so the beadblaster/large air compressor is out. I had hoped to be able to disassemble the pumps and toss them in something like the vibratory cleaner and forget about them for a while.
10-28-2008, 06:36 AM #7
- Feb 2006
- 3,711
MAC702,
I have a smaller unit (about 12" in OD) from Dillion. It works great on brass and nickel cartridges (rifle and pistol) prior to reloading. I have also used it with a few other things like the antique brass rollers on chair legs. It eventually removed the lacquer coating, but something other than corn cob media (maybe nut hulls) would work better on the tougher stuff.
Dillion is way cheaper than the link originally posted!!!
10-28-2008, 06:53 AM #8
Member
- Dec 2006
- Central Iowa
- 72
Handyman you might try Tail Strip also called Aviation Stripper. It's available at most better auto parts stores, reasonable priced and is easy on metal including aluminum. Just hose off when done.
10-28-2008, 07:50 AM #9
- Sep 2002
- Clark County, NV
- 2,696
Agreed. And you can't ask for a better company to deal with than Dillon. Would you believe I used to have the very first issue of their Blue Press? Back when they were newspaper size! I can't believe I don't know what happened to them. A collector's dream these days, probably.
09-22-2008, 01:20 PM #10
- Dec 2007
- PA
- 286
cleaning with vibratory tumbler
Hi handyman,
I have one very similar in size to your link. I got it to clean rifle cases for reloading and it worked great for this. For the brass cases, I used ground corncobs and a bit of jewelers rouge. I have also use it to clean rust off 3/4" diameter ball bearings. Used plain dry sand for the ball bearings (heat it in a metal drum to dry it) as damp sand clumps up. I would suggest using the cones or pyramids as this will speed up the cleaning process. It will be a slow process so be prepared to wait for at least 4 hours or more before checking. Also don't overload the mix with your parts as they will not allow the vibrator to develop the proper "motion". It should look like a milkshake in a blender when it is working correctly.
good luck
Thermal Arc GTSW400, Airco Heliwelder II, Miller Dynasty 350, Hypertherm 1000, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, etc.
