Results 11 to 19 of 19
    Stephens
    28
    Thanks for the input Marcel Bauer sounds like youve burned a rod or 2! Can you send pics of some of your smokers or grills?
    Built for somebody else and mine had to be left behind when I moved some years ago.
    "If you build it, they will come!"
    Sep 2006
    Abilene, Texas
    639
    I've done 2 grills from old butane tanks so I'm not too high on the list of "expert" grill makers, but I've trimmed the edges of the doors with 1 x 1/8 flat to cover the gaps. You can bend it by hand to fit. Grills are fun to make unless you are trying to make a profit on them. They are time consuming but I've enjoyed building them. Sorry, no pics right now. I can get a pic of the small one, 32 gal. The big 250 gal is where I can't get a pic of it anymore.
    Jim
    Stephens
    28
    Im buiding it for myself just a learning experience should be making money much as I have racked my brain Thanks JIM-TX
    Texas
    279
    When we build a pit, the top and bottom of the doors get cut first, tack the hinges, cut each end, ck for no binding, finish hinge weld. I generally add 1"x1/8" around the doors.
    Here is a pit SIL and his bud built (w/my supervision) from a discarded propane tank, fire box is 2'x2'x¼".
    Have fun
    L*S
    Stephens
    28
    Thats what I had in mind when I started my build,I hope it looks half as nice as yours LEON2003
    Nov 2007
    5
    Here is some pictures of one I built and sold. It is an old propane tank 30" diameter has 2 meat racks and has a single 4' door with counterbalance. The firebox is 2'x2'. Unfortunately I did'nt get any of it finshed. I hope this gives you some ideas.
    Stephens
    28
    Nice Work You all are making me jealous!How long did it take to make and how much profit do you make MIKE H?
    Nov 2007
    5
    I'm just a weekend weldor so it took me about 8months when I wasn't doing something else or if the temp. wasnt 100 degrees I made about 500 on it.
