It's a fancy way to add a couple $$ signs to the word curtain rod, so yeah as far as the ROC is concerned I'm good because all I have to do is FAB them the client willl have them powder coated and they will sit free standing thanks for the link I'll add it to my list to check out
Results 61 to 70 of 102
Thread: Labor Pricing HELP
09-23-2008, 01:25 PM #61
MILLER 180 W SPOOL GUN
MIller CP 300 w/S22-A Feeder
Miller Syncro 200
Miller 375 X Plasma
Miller Elite Hood
JD2 Bender
Tube Notcher
Horizontal/ Verticle Bandsaw
Makita Angle Grinders
Arsenal of handtools
Evolution Raptor dry saw
Single Stage 60 Gallon Compressor
Delta Drill Press
"No fear to learn by doing", and a degree in Redneck Engineering
09-23-2008, 01:28 PM #62
09-23-2008, 01:39 PM #63
Miller Syncro 200
Miller 375 X Plasma
Miller Elite Hood
JD2 Bender
Tube Notcher
Delta Drill Press
09-23-2008, 01:47 PM #64
- Feb 2004
- 1,161
The link I put up is the SBS checklist of every legal requirement to start a business in Arizona.
I think my link is unbeatable Broccoli 1.
JTMcC
09-23-2008, 01:56 PM #65
09-23-2008, 02:07 PM #66
You 2 just gonna play swords or what?
Thank you both for the linksMILLER 180 W SPOOL GUN
Miller Syncro 200
Miller 375 X Plasma
Miller Elite Hood
JD2 Bender
Tube Notcher
Delta Drill Press
09-23-2008, 03:27 PM #67
- Sep 2005
- 4,247
http://www.troutandpartners.com/team/jack_trout.asp
Most marketing campaigns fail, because
people do not understand competition.
Its all about specialization. Being outstanding
at one thing is far better than
being just good at many things.
This is one of the things that eats my lunch. It was simple to think that being good at something would win out in the end, not so. One of the things that make Picaso such a great artist, he died rich.Last edited by Sberry; 09-23-2008 at 03:41 PM.
09-24-2008, 08:30 AM #68
New guy here but i thought i would jump in on this since it was something i had trouble with as well. I basically took a guess on my pricing and it ended up meeting right with some thing i got right from a book (after converting inches to hours) with some slight changes. The book is "The welders Handbook" By Richard Finch. He recomaneds a dollar an inch + 1 dollar a tack weld and say that it still seems to low.
After doing some SS 6'' pipe and some large commercial handrails i found his numbers to be right within what i charge, so i have adopted it to give 2 pricing modes to people depending on if i'm doing all the fab & welding or if i'm just welding
I run a "mobile welding" truck around as well and my pricing is as follows.
MInimum of 25 dollars wether it's just something small you briong to me or for me to drive to your location and just look at the job. Then if time goes into an hour the first 25 applies to the hourly rate of 40 dollars per hour. On a strictly welding job where all parts are trimmed and fitted i do the 1 dollar a tack and 1 dollar an inch of weld. Then if it's SS or AL i go 1.25 per inch, and then add another .25 cents if the SS requires back gassing.
I know this thread is rather old, and i didn't read all replies, but just thought i would put this out there for the OP and for anyone searching just to see what things are going at in my area. MOst other shops charge between 40 and 60 an hour respectively, but since i have no shop overhead because i'm based from a place that i already work and have a decent metal shop at home i try and stay on the lower end of the scale to hopefully gain customers and revenue. I've owned a painting business for over 5 years and just this past year took welding to the "retail/commercial" level and so far things are good, business is picking up fast and i haven't been dissapointed with the money i've made on any project so far. Save for one recent job where i wasn't told of a 4 day deadline on 115ft of mild steel handrail set in concrete. When i wrote the bid they acted like i had all the time in the world, so i gave them a good price to get my foot in the door. But, i still came out at 30 bucks an hour afer all was said and done.
Sberry has a good point, I specialize in automotive/motorcycle fab & repair work and keep my rigs out at the track every weekend, I probably don't make as much as some one welding pipe for a living or just having "the weld shop" on the corner that does "whatever" and that's made the jobs that i do get very pleasing to work on and keeps the pay scale good. There's a lot of mobile welding shops in town (3 others) but by going to the track and talking with the other racers and showing them my work i broke into orking on a ton of drag bikes locally, everything from starter carts to wheely bars and Frames. I also specialize in CRMO4130 and ALuminum work because i like them so much more than all other metals and I practice every joint & weld position and burn through every bit of filler rod i can on these metals when i'm not working on a customer project so that i will have experience in every situation posible when it comes to these metals and so far it's all paying off very well.Last edited by turboglenn; 09-24-2008 at 08:36 AM.
Hobart Handler 135
Smith MB55A-510 O/A setup
Lathe/Mill/Bandsaw
Hypertherm Powermax 45
09-24-2008, 10:31 AM #69
Miller Syncro 200
Miller 375 X Plasma
Miller Elite Hood
JD2 Bender
Tube Notcher
Delta Drill Press
09-26-2008, 07:27 PM #70
Nice Response!!
Millermatic 210
Syncrowave 200
Spectrum 625 X-treme
Hobart Champion 16 W/
Miller 8VS Suitcase
Miller 3035 Spool Gun
Tons of Tools
Microwave
Laptop and Printer
Speakers in the Back for all to hear Sirius Radio!
AHHHH too many links! I just have a word doc I have been pasting them into until I can get time (ya know after my day job) to look them all over
