Page 5 of 11 FirstFirst 12345678910 ... LastLast
Results 41 to 50 of 102
  1. #41
    4,457
    If I am not mistaken Henry Ford had a day job while he was building the first of his cars?
  2. #42
    Mar 2007
    132
    I like reading everyone's experiences so keep it up.
    A couple of thoughts:
    In some areas the government/government agency paperwork and requirements is enough to stop any new business from starting. It's best to start one and then sort through the mess as you grow.
    My area isn't bad, and I started 'legit' and have insurance, but I've had several large jobs where I wasn't asked the first question about insurance. Of course most small customers don't care either.
    There is no one right way to start a business. Some people will take the big plunge and make it, some won't. Other's will keep their day job and make it, some won't.
    Pricing?
    Take your fixed monthly overhead (which might be very low if you do it on the side), and divide by 176. That's how much per hour your overhead is going to cost. Then take the hourly rate you need to survive and add it to that. Materials, add. Consumables for job, add. Fudge factor, add. PROFIT, add.
    Fixed monthly overhead should include advertising and general costs of doing business.
    Don't forget taxes.
    The above is very simplistic and general. You'll have other expenses. Just make sure you TRY to think of all your costs and don't do it for less than the amount you come up with.
    You might end up with a $5000 check, thinking WOW! and then start paying out of that until there's very little left...then you think: WOW!
    Good luck,
    James
  3. #43
    Jul 2008
    Avondale, AZ
    104
    Quote Originally Posted by walker View Post
    Speaking as the legit local, you actually do need a business license if you are going to do this regularly, no matter how much you make in a year. You need a contractors license for any job, or part of a job, over $750. You must have a bond to get a contractors license. There is also a bond you must have for the AZDOR, just to be sure you are paying all your sales tax.
    From all the research I did I didn't find anything stating any of this was required, despite the popular opinion I am taking steps to do this the right way, so if there is a link or resource that you know of and could pass my way I would appreciate it.
    MILLER 180 W SPOOL GUN
    MIller CP 300 w/S22-A Feeder
    Miller Syncro 200
    Miller 375 X Plasma
    Miller Elite Hood
    JD2 Bender
    Tube Notcher
    Horizontal/ Verticle Bandsaw
    Makita Angle Grinders
    Arsenal of handtools
    Evolution Raptor dry saw
    Single Stage 60 Gallon Compressor
    Delta Drill Press
    "No fear to learn by doing", and a degree in Redneck Engineering
  4. #44
    Jul 2008
    Avondale, AZ
    104
    Quote Originally Posted by FATFAB View Post
    So I am not full of SH!T one is required to acquire bonding and licensing and foolish not to have insurance.
    Hey, if your right I'll be the first one to admit it, I have no issues owning up to something if I'm wrong, but from the research and calls I made I could find nothing that required any of this, not saying it's not a good idea, or that some customers wouldn't require it, but nothing that said the state required it.
    The way I see it you guys have nothing to worry about it, you all sparked an uproar like I was going to take over the oworld of welding, if your good and skilled at what you do it doesn't matter how many hacks start up in my experience in my field anyway, because they'll fizzle out and those people that bailed for the cheap sh1t will be back at your doorstep asking for bids.
    Good luck to you and any small business owner, it takes a a lot of nut to take that leap, not knowing when and where your next buck comes from, I grew up in that enviroment.
    Miller Syncro 200
    Miller 375 X Plasma
    Miller Elite Hood
    JD2 Bender
    Tube Notcher
    Delta Drill Press
  5. #45
    Los Angeles
    2,934
    Quote Originally Posted by SinGear View Post
    http://tw.yumaaz.gov/WebWare/Default...sage=1560&t=-1
    You do business- You need License
    all dem little Guv'ment hoops- jumped just like a Circus Poodle too
    add an emplyee- F**k me- More hoops- but these cost more $$
    Fire an Employee- F**K me- god **** nudder hoop.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
  6. #46
    Jul 2008
    Avondale, AZ
    104
    Thanks Ed, don't live in Yuma but I'll go rut through the Avondale website and see what additional stuff I need.
    Miller Syncro 200
    Miller 375 X Plasma
    Miller Elite Hood
    JD2 Bender
    Tube Notcher
    Delta Drill Press
  7. #47
    Feb 2006
    Northern CA, Shasta CO.
    157
    Many of the licensing requirements are through the state and not necessarily the community of interest.
    Here's a site a couple of different ways.
    http://www.azroc.gov/l_gen.html
    http://www.azroc.gov/l_class.html
    I should edit to add that a business license and a contractors license are two separate items. You probably already know that.
  8. #48
    Apr 2008
    Rushville IN
    50
    Default Rates
    So, what are everyones rates?? Full or part time>>
  9. #49
    Jul 2008
    Avondale, AZ
    104
    Quote Originally Posted by Sandy View Post
    Yes I do, but thanks any and all information is appreciated, and even if it isn't something that helps me, then maybe it helps the next guy. I'll check out those sites and thanks for the leg work.
    Miller Syncro 200
    Miller 375 X Plasma
    Miller Elite Hood
    JD2 Bender
    Tube Notcher
    Delta Drill Press
  10. #50
    Mar 2008
    Anchorage AK
    344
    So many including your self have missed my point. If we expect the people running Freedy Mac or Fanney May or AIG to do the right thing then we must as well. If you expect your kids to follow the rules of YOUR house then they must see you following the rules of the country.
    In the end you likely won't affect the world of welding any more with or with out all the proper papers, nor will I.
    Right is right?
    Business especially small business was described to me this way. Every day you take out the family jewels, place them on a chopping block and first up is the gubment. They get a few swipes, next is all the other parasites, next are your suppliers, then your employees (the employee gets to swing from the all day long)your customers get a swipe or two.
    At the end of the day you pick them up and go home to have the family kick the a time or two (just to help the healing). No one is on your side except you.
    If you concentrate on sound business principles you increase your chances greatly.
    Honesty is your best friend, a good contract is always a win / win. some times you will win a lot more than (you) think (you) could.
    The times you take a bath doing a job(pay to do the work) are your BEST times to learn. Pay attention, figure out how it happened and put some process in place to prevent it.
    TJ
