Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: Tubing Roller
  1. #31
    2,957
    The Baleigh belongs to Otis Parsons Art School
    outta my price range too
  2. #32
    WY...armpit of U.S.A.
    659
    Grumple,
    I can't give you a heads-up on ring rollers. I don't have a need for one with the type of work I do...hobby guy. Too easy for me to hop in the pickup, head to the scrap yard 6-7 blocks from the shop and salvage something that will work for less than the cost of new steel...already made.
    Ed knows his ring rollers. Ask him his favorites, wishes, longings, whatever.
    If you don't want to send the bucks for a high dollar roller, build one. Gear reduction drive, motor and reversing switch should connect to a ring roller you made that will do the work you want it to do. No use spending big money...if this is a hobby.
    The concept it dirt simple with room to go overboard if that is what you want to do. Spend your money on other tools and build yourself a ring roller sized to fit your needs.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
  3. #33
    659
    Quote Originally Posted by Grumple View Post
    Ed,
    I just bought a lathe Delivered on Thursday but its not wired or even completely assembled yet and needs leveling and break in. So maybe I will just build me a ring roller. Looks like a fun project.
    Thanks,
    Grumple
    Forget the ring roller...you're gonna be too broke from buying lathe tooling.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  4. #34
    2,957
    Quote Originally Posted by WyoRoy View Post
    One of the reasons I do not own one- this hobby already drains enough money from da wallet
  5. #35
    659
    Rationalize all you want Eddie...I know its eating on ya'.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  6. #36
    2,957
    Nope- but a Mill is
  7. #37
    659
    Nope- but a Mill is
    You are gonna be one broke veggie!!! Give me a shout when you get one and I'll work you up a CARE package of tooling.
    EDIT: BTW, if you get the mill the lathe is just a matter of time...
    2nd EDIT: Should have bought that Bridgeport when you had the chance.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
  8. #38
    Sep 2008
    22
    Default hossfeld
    jallcorn,
    I already have a Compact Bender but that won't do it. Is the Hossfeld actually able to do full circles or 1/2 circles in a 12" diameter? I guess if they have a die that big but that would be a pricey die.
    Thanks,
    Grumple
    Look at Hossfeld's web site,
    http://www.hossfeldbender.com/advantages/index.php
    this page says what they can do. How well do they do it? Don't know yet but I just bought a #2 Hossfeld with 3 - 5 gallon buckets of dies. Haven't had time to look at it yet. My application will be bending scrolls, etc. for ornamental ironwork.
    3 weeks ago had to make 8 sets of rings to exact dimension, 1 set to fit exactly inside the other. Used an old trailer brake housing that just happened to be the exact diameter, and hot bent 1/2" square bar, then hot bent 1"x1/4" flat around the 1/2" bar still on the jig. Slow but worked. If I had had the Hossfeld then, would have tried to figure it out for that project.
    Hossfeld has a good reputation among blacksmiths that have them.
    Artist Blacksmith
    Historic Downtown
    Paris, Texas
    Dynasty 200dx
    Trailblazer 302
    12VS wire feeder
    Lincoln 215
    Miller Passport
    Miller 375 plasma
    Hossfeld bender
    Antique SA200
  9. #39
    Jun 2008
    Florida
    135
    I guess if I win the lottery it will be on my list of things I can afford to buy.
    Grumple
    Oxy/Ac Large Tanks
    Miller Swinger AC 180 (SOLD)
    Miller Syncrowave 250DX Runner with Pulser
  10. #40
    Jun 2008
    Florida
    135
    Grumple,
    I wish I could head to a scrap yard thats close by. The one I used to go to can't sell stuff to people anymore and thats where I would browse the yard and find all kinds of neat stuff I could use in projects. I guess I need to search out a new scrap yard. I have some time to figure out the ring roller as I have plenty to do in the mean time so I may just build one.
    I like your signature with the 40x59 shop thats too small. I know the feeling. Mine is 40x60 and although 1 foot bigger (actually 40 feet) than yours, its too **** small too.
    Grumple
    Oxy/Ac Large Tanks
