+ Reply to Thread
Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 10 of 51
Thread: Tubing Roller
    Jun 2008
    Florida
    105
    Default Tubing Roller
    I am looking to buy a tubing roller for round and/or square tubing maybe up to 1-1/4 or 1-1/2" capacity. I have seen these 3 wheeled tubing rollers and that is most likely what I will buy but I have a few questions. Are those cheap one junk or do they do the job like the high dollar ones? For example I found this one:
    http://www.harborfreight.com/cpi/cta...emnumber=99736
    And it looks like about what I need. Anybody have one of these? My next question is what is the smallest full circle diameter one could expect to make with this and finally, can these easily make repetitive items once you set it or is the pressure wheel have to be gradually tightened each time?
    Thanks,
    Grumple
    Oxy/Ac Large Tanks
    Miller Swinger AC 180 (SOLD)
    Miller Syncrowave 250DX Runner with Pulser
    Mpls, MN
    1,762
    They won't do repetitive bends without starting from the beginning after each part.
    Also, when you make progressive steps, the increments need to be close to identical between parts in order to hit the same diameter with the same setting if you use a mark on the travel indication for repetition. Any difference in springback or roll diameter is going to show up cumulatively. You can avoid that by simply measuring each ring as you roll them and use whatever tension is needed to hit your diameter or angle.
    I don't have any experience with that particular roller, but would suggest the draw type benders if you want consistency and don't need more than 180 degree bends.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Jun 2008
    Florida
    105
    Jim,
    Thanks for the info. I was actually hoping for 360 degree bends as in full circle. That is why the ring or tubing roller style. But thats what I was thinking on the repetitive bends so thats cleared up now. I guess if I can make them close enough is good enough.
    Grumple
    Oxy/Ac Large Tanks
    Nov 2007
    Saskatoon, Sask, Canada
    1,031
    I used to work at a shop that rolled 1" square tubing on a regular basis (for round bale feeders). A 24' length made the exact size ring that we were looking for, the boss built a hydraulically driven bender that rolled the tube in one shot. He had to put a few small tack welds on one of the dies to help suck the tube in at the start, so it left small dimples on the inside which in that case wasn't a big deal.
    You'd be amazed at the difference between bundles of tubing. You could have it set perfect for one bundle and the next tube you roll from a fresh bundle will give you two circles of tube! It's also a good idea to keep the seam on the inside of the bend (if I remember correctly).
    I hope my rambling has helped you!
    at home:
    2007 302 Trailblazer with the Robin
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    1,800
    Jim-Grumple
    You should be able to make 360- you have to push the ends side by side instead of Over/Under like with Flat stock.
    I did it this way for the Wheel on my roller, using a Powered Roller I had access to and you still had to roll the "Ring" with incremental pressure applied with each roll.
    This was a 26" Diameter wheel I imagine the smaller rings would be a beech to nudge the ends.
    Check here for what size Rings the roller will make
    http://www.harborfreight.com/manuals...9999/99736.pdf
    SP135 Plus (Sent to Rochester)
    Mpls, MN
    1,762
    Ed, I was just making the statement that if you needed consistency, and speed, and didn't need more than a 180 bend, that I think a draw type bender would provide better results as long as the diameter permitted using such a machine to form the bends.
    I'm aware these rollers will do 360's, but making consistent bends with small radii in any kind of production volume is going to take a lot of user involvement over the other option.
    This is also a situation where Chris' forming "halves" method might have some merit over doing a single hoop (depending on intended diameter). The time and expense of the second weld bead might easily be made up in the lack of time to form the ring (especially if it's a small diameter).
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    1,800
    Quote Originally Posted by Fishy Jim View Post
    ... needed consistency, and speed,
    It is a HF roller- So figgered that those words really were used rather loosely
    Mpls, MN
    1,762
    Ah, but I was suggesting he buy something else if he wanted either of those attributes.
    I wouldn't use the two to define a HF tool unless I was referring to how it would break.
    Have you looked inside their powder coating ovens? Mmmm
    So it was only a failure to properly connect the terminal with undersized wire, but I'm not sure that wire is rated for the 13A load it's designed to carry.
    I don't intend to keep this thing long enough to melt it again.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Crete Illinois
    175
    Grumple,, The hf roller most likely won't do the tubing sizes you want I have bent up to 3/4 inch square with it and got decent results but the tube starts to want to fold in on itself.....Round tube ive bent at one inch od , but talk about a struggle and hard to keep consistent.....and it also oblongs the tube on the bend radius..........so it won't be round tube when you're done.
    I've seen benders sold by Eastwood that had dies made for bending round tube that I have heard work awesome...about a $1000 for them though.....
    If youre gonna bend small square I'd get the HF ,,3/4 inch or under the Hf would probably be ok........OTHERWISE I'm thinking your gonna need something with a a little more MARBLES. My 2 cents worth JIm
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    JD2 Tubing bender with Hydraulic conversion
    Evolution Raptor15" SteelDry Cut Saw
    Hypertherm Powermax 30
    Some really cool hammers BIG and small
    Jun 2008
    Florida
    105
    Quote Originally Posted by c wagner View Post
    Thanks for the info. Its all good. I was wanting to roll smaller diameter tubing like 1" maybe down to 14-15" circle. I guess maybe the cheapo manual ones would be a chore to do this and I am not ready to spend big bucks on one so I may need to rethink this operation before I spend $$ on something that won't even work.
    Thanks,
    Grumple
    Oxy/Ac Large Tanks
Summer Savings Summer Savings
