Results 1 to 10 of 13
    Raymore Missouri
    1,925
    Default Price of aluminum
    I just checked with my local supplier of metal. I want to use 2"x2" x 1/4 wall
    aluminum 6061 box tube for the backbone of my heli project. They want $180.77 for a 24' piece(the shortest they have...no drops) Online with Metal Depot it would be about $97 more. How do these prices sound to you guys?
    I know aluminum is high but WOW!! Any feedback welcome.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Milton PA
    39
    Default Cheaper Source
    Try www>onlinemetals.com or www.Speedymetals.com
    Frank AKA Weekend Welder
    2,971
    Probably about the same here.
    16' 16g 1" tubing 30.00 bux.
    May 2008
    Austin Tx.
    101
    Do you know if there is a "Reliance Steel and Aluminum co." near you?
    Feb 2008
    902
    Default Look at scrap prices
    2x2x.25 sq ->
    (2-.25)*.25*4 sides=1.75sq in cross sectional area
    Vol=A*l=1.75*24'*12in per ft=504 cu in
    Wt= Vol*density= 504 cu in*.098 lb per cu in=49.4lb
    Market price = $$/lb=$180.77/49.4=$3.66 per pound
    $3.66 per pound is not bad for retail considering the fact that they are paying around a dollar a pound for scrap, or around 4 times scrap rate for retail.
    Contrast that with steel which I am buying retail for around $1.20 per pound (pipe) and they are paying $0.06 per pound to scrap it, or 20 times scrap rate. I lose 95% of my money on every pound of steel I scrap, whereas aluminum loses only 75%.
    And that same pipe was like $0.90 per pound last year. Our dollar buys less and less metal every day. Better lock in that price now!
    And be glad you aren't building this out of stainless or copper!
    Central Fla.
    311
    Haven't bought any aluminum lately, but where I buy my drops, the other day a 1 sq. ft. piece of 1/2" cr steel was $23.00. Unreal.
    turbo38t Guest
    I just bought 150' of 2x2x3/16 a500 steel tube for $560/foot but another shop wanted $9/ft. And a 1/2"x6"x20' piece of flat steel plate cost me$173!
    Nov 2005
    107
    I don't think you will beat that price much, but you might check with T&W Steel. They are in Lee's Summit Mo. and carry some alum. if you don't know about them. I bought a section of 3/16 x 2 x 4 Stainless about two months ago and it was around $700
    Raymore Missouri
    1,925
    Actually T& W is my local supplier and the ones that gave me that price. Where are you located? Are you in my area?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Raymore Missouri
    1,925
    Default Metal choices
    I've been rethinking the using of 2" square aluminum tube x.250 wall on my heli project being that I only need about 6-8 feet but have to get a 24' piece locally. Been reading a little on DOM on the metal site.........what steel is it? What does it compare to? Is it available in square 2x2 " tube? I understand 2x2"
    box aluminum x 1/4 wall is a little over 2 lbs per foot. Would 2x2" steel tube
    x .120 wall be as strong...stronger...weaker, and it's weight per foot as compared to aluminum? The two sites I have links to don't give all the info
    or I just can't find it. I do need to keep the weight down. Any info on this
    will be appreciated. I'm still looking.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
