Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Aug 2006
    near rochester NY
    9,881
    here is a better pic of the plug.
    i'm going to go ahead and replace the fuel pump. i need the car to be working again and the pump is the only thing thats off and on. power to it was still there yesterday when it would not run, so i'm calling it the problem. the wife needs the car to take her license test soon or she will have to take the required 5 HR coarse again before testing for her license.
    thanks for all the help and ideas.
    James
    as for the burnt plug i probably caused that when i sent power strait to the pump when it was stopped yesterday or the day before whatever it was. it was during on of the i'm not going to work times.
  2. #22
    Mar 2007
    9
    Default F4n
    Keep us all posted on how this turns out , because me for one , am very curious now , hope that solves the problem , Frank
  3. #23
    Aug 2006
    near rochester NY
    9,881
    i'll let ya all know how it works after the new pump.
    keep your fingers crossed for me.
    any way you look at it i want to replace the burned connector.
  4. #24
    Mar 2007
    9
    Default whats the answer
    Fun4Now, its been just over 2 weeks , so how did you make out with the fuel pump problem , where do you stand with it , or what was the cure , Inquiring Minds Whant To Know !
  5. #25
    Mar 2008
    Baltimore, Maryland
    315
    Man I'm slacking. I'm a former subaru tech, and I have many stock fuel pumps you can have. The pumps have intermitten(sp) problems and flake out. All pumps are in in good working order. We take them out and put big ones in.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
  6. #26
    Aug 2006
    near rochester NY
    9,881
    wow 2 weeks already ???
    i looked at ordering a new pump, but it would not get me new electrical plugs or a warranty. so i went with a used assembly from my local bone yard. this allowed me to replace the bad wire connectors and give me 60 days to return if it turned out to be relay instead of pump.
    so far so good, new pump assembly is working well.
    i been busy drywalling my sons room and getting my other new room dried in. i'll get back to ya asap.
