Results 1 to 10 of 15
Thread: Amperage
    Feb 2006
    Beresford N.B., Canada
    46
    Default Amperage
    Do any of you know what would be the best amperage for welding 1/8'' thick square tubing? I'm using a stick welder.
    ________
    Help In Love
    Feb 2006
    N/W Pa.
    39
    What are you using for rod ? Diameter ?
    Feb 2006
    46
    E7024, 3/32''
    ________
    LovelyWendie99
    Feb 2006
    411
    you should get a Welding calculator at the Miller online store
    they are only $1.50 shopping included
    but the best deal is you can get all 3 welding calculators Stic.,Mig,&Tig for only $4.00
    shipping included.
    Feb 2006
    N/W Pa.
    39
    Exclamation
    Will go out to my shop and check my chart and give you a range , talk to you in a few .
    Feb 2006
    N/W Pa.
    39
    Exclamation Ranges for 3/32 E7024
    E 7024 3/32" AC 65 - 120 amps . DC +/- 60 -110 amps . Jetweld 1 or Jetweld 3. start with a couple pieces of scrap and set your welder hot and adjust to get the bead you want. Hope this helps you
    Feb 2006
    46
    Alright, thanks for the advice!
    ________
    HALF-BAKED
    Feb 2006
    GA
    8
    A E7018 rod would work just as well, A E7024 are generally used for thicker materials and fillet welds
    Feb 2006
    46
    Well, I prefer using 7024 because of the beautiful results.
    ________
    Medical marijuana
    Nov 2005
    Buhl, Idaho
    53
    Quote Originally Posted by 2112
    Beautiful results? Im sure that 7024 does nice, but in the right hands 7018 can be almost perfect. I welded these with 1/8 MG 7018.
    Miller Trailblazer 302
    Miller 12 RC wire feeder
    Miller HF 251D-1
    Miller 175 wire feed
