Results 1 to 10 of 20
    Sep 2008
    Union SC
    78
    Default New Northern Tools Band saw
    I bgt one of those $350 band saws at NT the other day. I've prolly made 20 cuts and now it just stopped cutting. The saw is still doing it's thing but seems like the blade burned up or something. It spins and spins and no longer spits out any metal dust. Do these things need cutting oil while cutting?
    Millermatic 212
    1998 Heritage Springer
    Kioti DK55
    WY...armpit of U.S.A.
    659
    There are a lot of potential answers to that question. I would imagine that you are using the blade that came with the saw? Generally its junk as new. Swap out the blade for something of far superior quality...Morse, Starrett, etc, in a bi-metal blade, do a search for blade break-in, follow the procedure and you should be okay.
    Also, what material were you cutting/trying to cut?
    Finally, do a search for topics relating to these small saws. It will be easier/cheaper for you to gain the knowledge from others' mistakes and work-arounds than discovering them all firsthand yourself.
    Los Angeles
    2,968
    Do it still got teefus?
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    You just wore the teeth off a cheap blade (maybe even a wood-cutting blade) is my guess.
    Bi-Metal is the way to go, the extra cost is MORE than justified in service life. Works out a lot cheaper than carbon steel blades.
    "If you build it, they will come!"
    Los Angeles
    2,968
    I get mine from Enco
    http://www.use-enco.com/CGI/INPDFF?PMPAGE=553&PMCTLG=00
    Although it looks like they do not carry Morse anymore
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
    Sep 2008
    Union SC
    78
    Feels like the teefees is about gone. Preciate the advice. I ordered a few bi-metal blades from Enco.
    Yep, it was the blade that came with it. I had cut some 1/8 inch angle iron and 1/8 inch 1x2 square tubing. My last 2 cuts were on some flat stock that was thinner that 1/8, but not sure what it was.
    I will to see about proper break in on blade.
    Millermatic 212
    Kioti DK55
    Sep 2008
    Union SC
    78
    My saw says the replacement blade is 64 1/2 ". If I by one 65 1/2" will it fit or are those numbers pretty much set in stone?
    Thanks,
    Curly
    Millermatic 212
    Kioti DK55
    Los Angeles
    2,968
    Quote Originally Posted by curly View Post
    Thanks,
    Curly
    Dunno- but Enco has the length you need, why not order those
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
    64 1/2" is a standard length, you shouldn't have a problem getting them. I don't even know if they make a 65 1/2...
    You might consider tooth pitch, a rule of thumb is three teeth on the material min.
    For 1/8" you would want 24 teeth per inch, certainly not less than 16 tpi.
    Sep 2008
    Union SC
    78
    The only ones I could find on that site that were 64 1/2 were discontinued. How did you find it?
    I guess 24 tpi would be the size for 1/8 inch material then huh. I guess that will be what I cut the most.
    Are you saying if I cut 1/4 I need 12 tpi or 1/2 I should use 6 tpi?
    Glad to know 64 1/2 in a normal size.
    Millermatic 212
    Kioti DK55
