Results 1 to 10 of 16
    Apr 2008
    dallas,tx
    207
    Default drill press recommendations
    Looking to pick up a decent drill press without breaking the bank. Budget is
    4-600. Average use is 1" holes in 11ga tubing, and up to 3/4" holes in 1/2" steel. Would like to find something locally in the Dallas area. Any input is greatly appreciated. Floor mount would be my preference
    Scott
    Apr 2008
    171
    i looked all around at the stores and on line
    the best deal was at home depot .com
    a jet jdp-15mf it was $429.00 and free shipping
    it works great
    Feb 2008
    893
    Default Made in China?
    You could get one from harbor freight for less than half that. The Jet's I've seen lately look just like the harbor freight model. I think they are all made in China.
    2,908
    Quote Originally Posted by Bodybagger View Post
    True- but there are some Chinese tool brands better than others- Jet being one of them
    Sep 2008
    Union SC
    78
    I have a 14" (I believe) Delta drill press that I bgt for woodworking. As long as I use metal bits it's fine for whatever it'll drill, right?
    Millermatic 212
    1998 Heritage Springer
    Kioti DK55
    WY...armpit of U.S.A.
    659
    In that case, buy from Grizzly. I doubt you'll find a difference other than the paint and the price. Quality control is different from one importer to the next, but I believe Grizzly holds about the same or better standards than Jet. Otherwise, not much difference between any of the Asian drill presses. Taiwanese would be better than ChiCom, if you can find the country of origin.
    As far as Jet quality goes, as a Jet owner I've never noted their product as being one that strived for quality much past the flashy paint job. Forget white and go green and enjoy the extra cash and better customer support.
    Finally, drill presses are on the low end of product development and innovation. Not hard to find a decent model...even from Harbor Freight.
    659
    Quote Originally Posted by curly View Post
    I have 1 14" (I believe) Delta drill press that I bgt for woodworking. As long as I use metal bits it's fine for whatever it'll drill, right?
    Curly,
    Sure it will be fine. Just realize that most of the cheaper drill presses...okay, ALL of the cheap drill presses...run at too high a speed for most metal drilling with larger bits. Keep the cutting oil running freely.
    Sep 2008
    Union SC
    78
    Quote Originally Posted by WyoRoy View Post
    Curly,
    Thanks, now is cutting oil different than any other oil, or can I use anything?
    Millermatic 212
    Kioti DK55
    659
    Depending upon how much drilling you actually anticipate doing in the future, you can get by with regular oil, but it will be messier during clean-up and not provide as much benefit when doing the actual drilling. Better than burning a drill though, by any means. Try for some water-soluble cutting fluid/oil and your clean-up chores should be shorter.
    2,908
    Good to know- deciding between the Grizzly or Jet Swivel head bandsaw.
