I was reading an article that recommended using a 120-150 grit grinding wheel for grinding the tips for my tungstan. Would you guys agree with this? Also I went to Home DumpO and all they had was medium grit wheels, what would a medium grit rate at numbers wise?
Thanks![]()
Results 1 to 10 of 29
Thread: Tig Grinding Wheel ???
07-01-2007, 05:46 PM #1
07-02-2007, 01:25 AM #2
- Apr 2007
- Ventura, California
- 102
Try BOTH 80 + 240 grit
Its a trade-off. The larger the grit number, the finer the finish on the electrode tip. The finer the finish, the less arc wander, the happier the welder.
However, it will take FOREVER to cut the end off and regrind the tip with just a 240 grit. I solved this by using an 80 grit to cut-off and remove the majority of the material to create the tip. Then put a fine finish on the tip with the 240 grit.
Normally this would require a grinder with 2 wheels. I needed something more portable than a traditional grinder, so I took a cordless Dremel tool and purchased some diamond embedded grinding wheels. I sandwiched a 240 grit wheel on top of an 80 grit wheel and mounted them both on a single mandrel. The 80 grit makes pretty quick work of the cut-off and tip angle. Finishing off with the 240 gives nearly a glass smooth surface.
During the final finish, be sure to keep the direction of the grind along the length of the electrode (NOT going at right angle to it). The arc will follow the direction of the grind, so keep it going toward the point.
I got my wheels on eBay for about $5 each, including the mandrel. The Dremel tool is their Lithium cordless model, runs around $80. Its battery holds a charge for a long time. I get about 30 sharpenings before needing to recharge.
I keep an extra battery handy.
07-02-2007, 01:38 AM #3
Samurai Dave
thats a good idea, i might just have to give that a try.
i been looking at 6" D-wheels for a bench grinder to dedicate to tungsten, but they are prity expensve.
james@newyorkmetalart.com
07-02-2007, 02:33 AM #4
- Dec 2006
- collinsville, ok
- 86
i guess i'm a bit crude
i just chuck my tungstan up in a cordless drill and sharpen it on my angle grinder. i guess it ain't perfect but, i havent failed but one tig x-ray.
07-02-2007, 08:43 AM #5
[QUOTE=
[/QUOTE]
The article I read is in the July issue of Custom Classic Trucks, and they said to grind the tungstan at the right angle and they say never grind toward the point. I've tried both ways and last night with a right angle grind, I seem to have a lot less wondering, could I be wrong
Looking at your pics you posted, it looks like I need to grind at a much lower angel.
I like your Dremel idea. I have an extra one that I'll have to set up tonight and give it a try.
Samuria Dave
07-02-2007, 02:45 PM #6
i have always read grind in the direction of the tungsten, not acrost.
i wonder if it could have beed a misprint?? D-G advises to grind in the direction of the tungsten, thats all they do and they are defenetly one of the best in the field when it comes to tungsten.
i would wright the editor for a clarification. if the arc fallows the grind and its acrost the tungsten, how could it come off the tip strait at the work???
i would stick with grinding with the tungsten.
07-02-2007, 03:41 PM #7
- Apr 2007
- 102
Pricey TIG grinders
Indeed, there are some very NICE dedicated TIG electrode grinders out there. The one I like has water with the grinding wheel to keep everything cool, AND to collect the grinding dust. However, they cost an INSANE amount, like more than some TIG welders.
Speaking of tungsten dust, I always wear a respirator or mask, especially if grinding Thoriated. (Don't mean to sound like a wimp, but I just don't want to risk lung cancer, no matter now remote the chance.)
07-02-2007, 06:16 PM #8
- Nov 2006
- Hampton, Va.
- 383
Tunsten grinding
I agree with tsalagi I also grind the tungsten on my grinding wheel and keep on welding. I have welded ss and went to carbon using the same ground tunsten and in 27 yrs welding nuclear pipe on subs I never had any problem. I think everyone has a preference and mine was grind it by rolling it along my angle grinder no matter what kind of metal other than alum and keep going. I also used the same wire brush on all types os metals but alum.
Just my opinion
Wheelchair
07-03-2007, 03:58 AM #9
- Dec 2006
- collinsville, ok
- 86
hey wheelchair,
glad to see i'm not the only backwoods around. i found out that if i use a wire brush that has been used on carbon on duplex i'll get rust on that weld. if i use a 302 stainless brush, it's all good.
fun4now asked a good question. how do you keep a steady arc if there are ridges all down the tip?
07-03-2007, 04:38 AM #10
Samurai Dave
dont feel bad about safty, i would never even boither to use thorated for just that reason, too many better options out there, 2% lanthanated works great for AC or DC and will work just as well in a transformer as it dose in an inverter. no point in risking it is how i see it.
as for the dedicated grinder's, your wright its insane how expensive thay are???
i was not talking about getting one of then but rather just getting the D-disk to put on my 6: bench grinder. they also have some due grit options. in comparisin to the dedicated grinders they are prity cheap at $40-120 a disk, far better than buying a PIII price wise but the PIII is suposed to be a great grinder, just way too much $$ for me
they do cover the grind direction isu though, if they set up a $2000= grinder to grind with the direction of the tungsten tword the point, it must be the best way to do it. only thing i can see this guy saying grind sideways for is it might be safer from a kickback point of view ?? but i suspect its a typo, again a letter to the editor would be in order if ya ask me.might even get ya a free subscription renewal out of it.
