Results 1 to 5 of 5
Thread: what metal?
    Sep 2008
    25
    Default what metal?
    I would like to make some metal bars for weight lifting. I need them to not bend and be able to hold up to like 5-6hundred pounds. like 1in diameter any help?
    Sep 2008
    25
    thanks any idea of a close price per foot?
    Jan 2007
    Montana, USA
    228
    Quote Originally Posted by themayor View Post
    Why waste time building something that is so cheap to buy?
    http://www.pacillo.com/category.asp?area=6&sub=8&f=46
    Jan 2007
    Rosetown, SK.
    519
    Have made 2 this year for the firemen in training in the city. Used 2" T.G.P. or turned,ground & polished grade 1045 same as used in a hydraulic ram without the chrome. Was 7 ft. long & knurled in the lathe with a diamond pattern to give hands a place to grip.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    Sep 2008
    25
    I agree you can buy some of them cheap but i am looking to make odd ball bars like saftey squat bar and a football bar they run like 200 or more.
    How did you like them with the 2in dia the hole way? would be great for grip work
