Thread: tig
    Aug 2008
    Default tig
    Hi, I`ve got a question. I have a Miller thunderbolt AC/DC. Can I tig with it and what do I need to do it? Torch,Gas???? And does it work? I would like to learn to tig then maybe buy a dedicated machine if I see that I will use it. Also what torch would be good for this application thanks.
    Sep 2008
    Mt. Belvieu Texas.
    7
    Does the thunderbolt have DC-?
    You need argon, a dry rig and a few other things. Run your argon to your dry rig, connect your dry rig to your thunderbolt. Set your machine to DC- and turn the amps down a bit. I know this is rough but it gives you a general idea.
    Measure twice, cut once.
    Oct 2005
    Bulverde, Tx
    1,244
    Yes it can be done, but it is rough. I did it with mine. Your torch will need a gas valve. All you need is the torch, argon and the Tbolt. Scratch start is all you have and DC only unless you rig in a Hi Freq unit somehow. It will let you get a little practice, though.....although you would learn more with a real TIG unit. I was learning more with my TB than the Tbolt. Well, I did almost perfect tungsten prep with the Tbolt. You learn how to contaminate them very well with the Tbolt.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Sep 2008
    Mt. Belvieu Texas.
    7
    That does sound pretty rough.
    Aug 2008
    THanks guys, I maybe better to wait, me wants an engine drive anyways. I would be money ahead.
