Results 11 to 19 of 19
Thread: Balcony Railing Project
09-21-2008, 12:12 PM #11
- Nov 2007
- Central Idaho
- 190
Codes
09-21-2008, 08:59 PM #12
- Mar 2006
- Queens NY
- 1,547
Thanks for all the advice. I will do my research before i do anything else. Unfortunately contract negotiations are going south so i won't be spending a penny until it gets sorted out.
Dynasty 200 DX
Millermatic 175
Spectrum 375
All kinds of Smith OA gear
09-23-2008, 02:46 AM #13
Here's a place to start for ideas...
http://www.artisticironworks.com/dbrail.html
FATFAB hit the nail on the head.
The International Building Code requires railings to be 36 or 42 inches high... 36 for residential (as in single family residence) and 42 for commercial. An apartment complex is generally considered commercial. It appears that the existing rails are only 36 though. Hard to tell because I'm judging scale from the guy at the bottom.
No opening should be wider than 4".
The fuzzy part is that the rails have to withstand a concentrated load of 200 lb applied. That's a pretty long span across those columns for slender tubing to withstand 200 lb applied at the middle without excessive deflection.
Whatever IBC says... Whatever NYC has adopted from it, the ultimate test is whether the building inspector likes it and likes you. Sometimes they don't even look at it. NYC Department of Buildings even says on their website:
"Difficulties in understanding the Code has led to confusion, inconsistency, delays, and added cost for construction within New York City.
Lack of clarity within the Code and the need for various types of review leads to increased corruption hazards."
They pretty much tell you to have cash ready when the inspector comes.
Equipped with red and blue... and red and green!
09-23-2008, 08:06 AM #14
This might be too obvious but... search Google Images with a simple query of "balcony railings"
I got some nice pics at the link below since I recently considered a similar project:
http://images.google.com/images?gbv=...ilings&spell=1
09-23-2008, 11:46 AM #15
- Mar 2006
- Queens NY
- 1,547
Bodybagger-
I don't think the existing railings are 30" high! Luckily for me it's not in NYC. Actually it's close to canada. From what i understand, there aren't many codes or inspections that take place up there. I have no intentions of building anything shoddy or questionable. I take any safety related thing i do very seriously. I will likely build a test railing first and determine fit and strength based on that, the columns are likely to be replaced. Maybe with 6x6 or 4x4 with an outer decorative cover. Either way the attachemnet method will be robust and i can also screw feet into the decking for verticle loads.Dynasty 200 DX
Millermatic 175
Spectrum 375
09-23-2008, 11:51 AM #16
- Mar 2007
- Deltaville, VA
- 2,241
Laiky,
Good advice with regards to meeting local building codes.
The only thing I've got to add, after seeing the scope of said project. It isn't going to be CHEAP no matter how you go. With the price of steel today, that project will cost twice what it would have 18mos ago.
Good luck.
09-23-2008, 03:42 PM #17
- Sep 2008
- 29
I worked at a shop specializing in gates, railings, etc. We would use 2x1 tubing for the hand rail, 1/2"x1/2" square tubing for spindles, 1/2x1/4 flatbar for the sub-rail, 1x1 or 1 1/4x1 1/4 square tubing for posts, and on the end of the square tubing where the rail attaches to the column we would weld a piece of 2" x 1/4" flatbar (tabs) maybe 4" long with two holes drilled in it to attch using screws, on the sub-rail a 1" piece. the type of screws depends on the material you are attaching to. Any span of more than about 6' requires a post to be welded in the center of the length, so if you had a 10' railing you would want a post of 1x1 or 1 1/4x 1 1/4 in the center with a pience of flat bar on the bottom with to holes for attaching to the deck. This can go underneath the 2x1 handrail for a nice finish (a 10' piece of 2x1 with the post welded in the center. Also, in most cases the maximum distance from the sub-rail to the floor or decking is 3".
And ...as bodybagger mentioned the 36",42"and4" are important. The 4"is the max space between spindles so remember this when calculating your spacing. If your spacing for the 1/2 x 1/2 is exactly 4" or anything less you will only have about 3"-31/2" between spindles and this can look to small. Just never go more than 4" on the spindles and never lower than 36" on the height. For the particular job your doing its a good idea to check code and see if it requres 42". In the end you have to tack everything up and take a step back to look and see if it looks right. This is the tricky part. If you se a design similar to the one i mentioned, and you weld all joints completely with solid mig welds strength will not be a problem.
One last point, if welding long sections it's a good idea to brace the top (2x1 for instace) by clamping a piece of thick angle iron of whatever you have. The whole thing will want to warp when you weld it and it can become a real pain to bend back into shape. This should help keep it straight.
Good luck
09-23-2008, 07:07 PM #18
- Mar 2006
- Queens NY
- 1,547
Thanks again, i'm taking notes!
Is there any restriction on making the railings in 2 pieces (left and right) and bolting them together? not sure yet how i'm going to ship 8'-10' sections, if it comes to thatDynasty 200 DX
Millermatic 175
Spectrum 375
09-23-2008, 09:59 PM #19
Consider steel columns and wood rails?
I designed and built a 2 story deck a few years back that reminds me of your situation. It was a complete rehab of a failing deck. But I did the opposite - used steel for the columns and wood for the railing. Columns were continuous HSS 4"x4"x1/8" sq tubing with brackets and connecting hardware welded off site... columns were installed first and everything was bolted or nailed into place. Even the handrails were all identical - made on the ground and bolted into place.
It was a LOT cheaper to do wood rails.
Everything was 10 feet on center, like your columns.
BTW rails are 42 even though it is single family residential... it's a long way to fall!
