Results 1 to 3 of 3
Thread: e71t-1
    TAYLORMADE Guest
    Default e71t-1
    hints on running e71t-1 3/16 wire on 1/4 inch plate in vertical postion
    Jun 2007
    San Diego CA
    32
    Default wire welding
    the wire that we use in the feild is no bigger than 5/32 and that is
    NR-211mp lincoln wire
    the other wire we use is NR-232 and that wire is .072
    and the last one we fall back on is the good old 7018
    1/8 inch is the all out weld in any spot
    the wire you have sounds like ship yard welding that is where i
    have seen wire that size
    Jun 2006
    Calgary, Alberta
    377
    I think you mean 3/32" wire, and that'd be mighty hot and fast! Sorry, I've only run an E71T-1 1/16" wire in the vertical position, and on 1/4" plate I think I'd have troubles knowing where to set the machine to avoid meltdown. I've only run 3/32" flux core in flat and horizontal positions.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
