Results 11 to 16 of 16
Thread: go kart
    Vancouver BC Canada
    605
    Default Vroom Vroom!!!
    I need an engine..... any ideas?
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Indiana
    541
    Dang Signwave, those sure are grippy tires to stick to the wall like that.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Apr 2008
    Toronto Canada
    30
    Heres the one i put together last summer for ****s and giggles
    Garage Guy Chris
    equipment:
    -Miller matic 210 w/ spoolgun
    -Syncrowave 180SD
    Apr 2008
    Toronto Canada
    30
    some more pictures stupid 5 pic max...
    Garage Guy Chris
    equipment:
    -Syncrowave 180SD
    Mpls, MN
    1,762
    Yeah Rich, use a 1000cc crotch rocket motor.
    I'm actually getting a rascal scooter that broke the output gear on the motor to use for parts and make an electric cart for the kiddo. I figure if that thing used to haul a 275lb man up hills and over rough terrain, I can make it haul a 40-70lb kid at a pretty good clip.
    The motor is an odd configuration where the bearings are integrated into the mounts and the armature has an integral pinion that rides against the ring gear on the diff, so I might scrap that in favor of another motor. But the speed control and integral charger along with all the needed circuits already there should make it a pretty simple chassis build and drive train swap over short of needing to do something about the differential. The scooter even has heim joints for the steering linkages, so it's rich in components to pillage.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Washington State
    I don't know where you plan on using it, but the first one I built I used the standard clutch you see on most go-carts I upgraded that to a torque converter and wow did that make it fun. It could climb hills with two people in it and it had some top end too.
    Tom
