Results 1 to 7 of 7
    Seabrook, TX
    43
    Cool New Miller Hemlets???
    The digital elite series has a Lens Power control of Manual-On and Auto-Off... What do they mean by Manual on? Is it still auto-darkening? I'm sure it has to be. Someone enlighten me, I am a bit confused.
    They don't call me Lucky for nothin'.
    Alberta
    60
    Quote Originally Posted by Lucky View Post
    Means you have to turn it on before welding unlike the performance series i have that turns on as soon as the arc is struck. The auto off just turns it off after a few minutes of no use to save battery power.
    Seabrook, TX
    43
    As not to run the battery down, I guess. So, it is still auto darkening. Thanks!
    You have to turn the helmet on as you start to work, not before every weld. If some minutes go by without use the helmet will turn itself off.
    I haven't used the Miller model, but I think it is always dark if the power is off. Turn the power on and you have an auto-darkening helmet. If several minutes pass without use it will shut the power off again.
    These helmets may leave the power on if you set it on the bench looking at a bright light on the ceiling (I THINK...)
    "If you build it, they will come!"
    Fraser Valley, BC
    593
    Quote Originally Posted by Marcel Bauer View Post
    Unless the D-Elites have change, the miller helmets all default to there light shade. If you forget to turn it on you'll end up seeing spots for a second or two, kinda annoying, but you'll become trained to turn it on after a while.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Sep 2008
    Delta B.C.
    33
    Yup when off you will get the flash.
    My teacher got flashed while giveing a demo.
    I have an optrell and love it!
    my welder is miller.
    my optrell works off of solar power only no battery.
    There both about the same cost
    Read up on both and see what you need.
    Alberta
    60
    Optrel Satellite will definatly be my next helmet. Mom works at Air Liquide so I can get it for their cost, $275.
