Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
    Raymore Missouri
    1,907
    Default Aluminum Tig ? for the pros or whoever
    I'll try to explain without pics..... I have a 6" diameter aluminum disk x .125 thick. I also have a 6" ID x .125 wall aluminum tube. The disk will fit into the
    end of the tube flush with the end. It's a snug fit. I want to tig these together. I also want the weld to be flush. Do I v taper the inside of the tube
    and taper the disk so when they come together there will be a V to fill and then grind flush. This has to be perfect. It will be spinning about 1000 rpm
    What sequence... do I spot, then weld to have it stay true? Explain. This is the gear enclosure for my helicopter project that will hold oil..
    KB hellllllllllllllllllllp!!
    Thanks ..............................Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    1,567
    It will work the way you are describing with the "v" groove. Six long tacks (about 1" each) evenly spaced & then weld it up.
    1,567
    You can also line up the inside corner of the plate with the inside corner of the tube so will have an "outside corner weld". This leaves you with a nice area to fill up with weld & less sanding.
    Jul 2008
    26
    +1 for the outside corner idea. Also it might not be a bad idea to leave a 1/16" gap or so to make sure you get good penetration into the joint, because welding both sides would be difficult given the tight space inside the tube. A gap will make it easier to make it not leak as well.
    The outside corner could be "trued" in a lathe, without removing much of the weld, leaving a stronger joint in the end.
    If you need help, I'd be glad to lend a hand. I love projects like this, and it makes it even better that it's for a helicopter.
    Later,
    Kev
    Raymore Missouri
    1,907
    I understand the corner but the end plate is only 1/8" thick and it would be difficult to extend it out of the tube to make a corner joint and keep it square with the tube. As far as the gap idea which is good..............I have the problem of keeping the disk centered in the tube without elaborate jigging. This needs to run very true as it spins. The tube is about 5" deep
    so welding is out..... at least for me it is.
    Another question.......The tube will have about 3" of oil in it. I'm torn between
    thinking the oil will be slung to the outside and not having lube in the center where it is needed...............but I'm also thinking the oil can't really grab the walls of the tube and will never reach the speed/force to totally stay at the outside wall. What are your ideas? I guess I need to spin a can with liquid in it and see the results. I might be going with the second thought.
    thanks for the replies.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    I just made a model with a cordless drill and a plastic cup with water.
    The water spins to the outside wall alright! That was only at about 200 rpm. Any faster and the water would have climbed out the top.
    I also like the idea of a corner joint/weld. Accuracy in fit-up is no problem, just use three spacers exactly the same length on the inside at 120 deg.
    "If you build it, they will come!"
    National City CA
    1,086
    Tack it up evenly spaced around the diameter taping it into place as you go, Spread your heat out too. Tack one side then the other. you could set the tube upright one end over and other 5" tube or pipe this would hold and support the end cap as you weld.
    Penetration should not be and issue with 1/8" material, Blow through maybe but not lack of penetration.
    I've done jobs like this before where you just have to shim everything to fit.
    It can be done and no elaborate fixture required.
    And 1000 RPM's is not that fast considering it's weight. If you were off and 1/8" on the weld you would never see any vibration 3000 rpm maybe but not 1000.
    And yes oil will stick to the side of the tube two ways to over come this with out lowering the speed is one use thinner oil or two use more oil.
    Exactly what is this thing going to be????
    South bend lathe 10LX40
    K.O. Lee surface grinder 6X18
    Auto shades are for rookies
    www.KLStottlemyer.com
    2,636
    Quote Originally Posted by kcstott View Post
    "This is the gear enclosure for my helicopter project that will hold oil.. "
    Nick, how about some more details for the curiosity in all of us? You know we can't possibly do this job justice until we know all the details...
    Raymore Missouri
    1,907
    Quote Originally Posted by Marcel Bauer View Post
    See "Flying Project" thread I started on 8-08. Pics there of the rotor head
    I'm making.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
