Post #4 is different than what you just said. Still confused.
Results 11 to 20 of 38
Thread: spray welding
07-11-2007, 07:23 AM #11
07-11-2007, 07:31 AM #12
monte55
My bad! I started typing before I was done thinking. post 4 is correct argon/ oxygen mix. Sorry, Dave
07-11-2007, 07:37 AM #13
Then is 90/10 correct being argon/co2 ?
07-11-2007, 07:49 AM #14
- Sep 2005
- 821
The MM 210 will spray arc an .030 solid wire real well, with a gas mixture of 98% argon / 2% oxygen, also known as 98/2. This is really about the only gas mixture worth try to use for spray transfer with a MM 210.
Understand though the 210 doesn't have the duty cycle to be a production unit in spray transfer mode. For home use, and farm repair work it works just fine.
07-11-2007, 07:50 AM #15
- Sep 2005
- 821
07-11-2007, 07:58 AM #16
Thanks guys for the comeback guys..........I really want a 210 or a 251
07-11-2007, 08:16 AM #17
- Sep 2005
- 821
Due to the higher heat input, the spray transfer arc that your 251 is capable of producing is best on 3/16" and thicker mild steel. Really no need to spray arc anything thinner then this anyway, because as long as the machine is set correctly, an .030 solid wire and C-25 are quite capable of producing very sound welds on 1/8" and thinner.
07-11-2007, 08:44 PM #18
Danny, thanks a lot! Will try it this weekend
I'm not late...
I'm just on Hawaiian Time
07-12-2007, 02:16 AM #19
Danny, is there anything special, different mig tip, etc.? or do you just turn up the heat?
thanks,
bertI'm not late...
07-12-2007, 04:06 AM #20
i think its just the power causing the steel to liquefy sooner rather than when it comes into contact with the steel like in short circuit transfer. same with globular no special equipment consumables needed just the proper setting and gas.
gas being a big part in the MM210 as its at the top of its settings to reach spray. not shore about needing it with the 252.
james@newyorkmetalart.com
