Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. #21
    Oct 2006
    Mpls, MN
    1,790
    My technique has always been to measure out and mark the circumference on the material and leave enough for tails, then roll it till the lines are close enough together.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
  2. #22
    Aug 2007
    Central Fla.
    311
    Chris - That's the reason I asked. I've always rolled in one piece and accounted for the flats as Broccoli said. Just thought I might learn a new and better way of doing it.
    Thanks.
  3. #23
    Apr 2006
    San Diego
    375
    I've always done the same thing for one piece, too. In fact, all my planning was to do this project with one piece rings, just like every other freakin' ring I've ever rolled. Then somewhere along the way I lost my mind and listened to someone who would have done them in two halves. In fact, I even had the material all scribed up for one piece.
    At go time, I cut everything in half, and the rest is my PITA.
    I'm so beside myself I want to cut these ones up, buy new material and start over. Anyone want a roller?
    I need to take another six months off... ... but I gotta eat.
    I'm done posting. You'll all never hear from me again.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
  4. #24
    Apr 2006
    San Diego
    375
    I will say this: it was tough to get the one piece ring out of the roller, and with material 3/16" and up, one would have to remove the top roller to get the ring out, or you're in for a fight.
    I swear I've lost my mind.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
  5. #25
    Aug 2007
    Central Fla.
    311
    Don't be so hard on yourself. You did something new and made it work didn't you?
    As for the ring roller, PM me and we'll make arrangements for the transfer.
  6. #26
    Apr 2006
    San Diego
    375
    Default more pics, finally
    Hello everyone.
    I've been real busy, so I'm finally getting around to posting some more pictures (if anyone really cares).
    1 and 2) Jigged up for welding the vertical tubes. The tubes are 3" x .120 wall. I had the 3/8" plate waterjet for a press fit so I could do the welds on the underside. I used this table to jig it all up square.
    3) This is how the underside of the stands looks. Basically this is what I see before I weld the tubes. No one will see any of this, except some bugs or really small people.
    4) Welded. All of these welds were done as jigged up, so it was good practice for OOP stuff. Although, it seems that most of my work is OOP.
    5) Zipped up. I needed full 60" lengths which I got from 20' pieces. The ends of each 20 footer were creased as you can see in the photograph. I put it towards the backside and the pictures shows it to be much worse than it is in real time. No big deal.
    Thanks for looking.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
  7. #27
    Apr 2006
    San Diego
    375
    1) Stacked up. There were eight of these in total.
    2) I TIG welded the seams of the skirt and buffed them out. I can control the fill better with a TIG weld so there's less post-weld grinding on a joint like this. I just welded these up as they sat stacked on the cart in the previous pictures. Not the prettiest welds, but I was cruizin' for speed and gettin' er done.
    3) Mounting plate welded across the tubes. This will receive another bracket from which the monitor will hang.
    All in all, this project came out pretty well. It wasn't my design, but I was happy to oblige. I'll try to get some pictures as they sit painted and installed once the building is finished. I'm just glad they're gone and I can move on to the next project.
    Thnaks for looking.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
  8. #28
    Apr 2006
    San Diego
    375
    Lightbulb For Broccoli
    Quote Originally Posted by chris***@sbcglo View Post
    Don't bother. I'll post them myself.
    ...sometimes the bear eats you.
    1, 2, 3) One piece ring. Ahhhh, geeeeez.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
  9. #29
    Oct 2006
    Mpls, MN
    1,790
    I think they turned out pretty good.
    Are the seams at the edge of the plate/rings going to be left visible, or will those be filled by the painter?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
  10. #30
    Apr 2006
    San Diego
    375
    Quote Originally Posted by Fishy Jim View Post
    The skirt was tucked under the edge of the plate by 3/16", so the seam won't be visible unless you're less than 5" tall.
    Glad it's done.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
