Chris*** - Just a question. Why do you have to roll the rings in halves?
Thanks.
Results 11 to 20 of 39
Thread: Plasma screen stands
09-05-2008, 09:55 AM #11
09-05-2008, 10:37 AM #12
With pretty much any 3 point roller you end up with a flat on the beginning and end of the raw stock which accounts for the distance between the center and outside roll. You can roll the ring to compensate for the excess, or you can roll it to diameter and half it like Chris does.
If you don't mind 2 seams, Chris's way is faster and easier. Especially with thicker material, you end up fighting it when you reach diameter with the excess for the ends.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
09-05-2008, 12:14 PM #13
- Apr 2006
- San Diego
- 375
You can roll some stock with one seam, like the wheel I made from 1" round tube for my roller. Stock like this has enough spring to it that you can pull it to the side of the machine to complete the circle.
Like Jim said, 5" flat bar doesn't have a lot of give, so I did it in halves.
I was originally going to have another fabricator (who has MUCH more experience than I do) roll these up for me. We talked about it and he said he would probably do it in halves for the same reasons. He also mentioned that the end result would have a truer radius. With more projects lining up, I decided to make my own roller, but I still took his advice and did it in halves.
I'm not sure if I could have done it in one piece. It's too late to find out for this job.
Maxstar 200DX
Maxstar 300DX
Passport
Spectrum 701
LMSW-52 spot welder
09-05-2008, 02:23 PM #14
You have to have the stock cut to length which includes the "Flats" at each end.
Example: 6" Ring
Circumference = 18.84
then add however much material is taken up by the Flat at each end by the type of roller you are using.
So if it is 2" then the stock is cut to 22.84"
Place the stock in the roller like in the Photo, apply a little pressure, roll through one way till you reach the "Flat", apply pressure, roll it back.
Repeat until you have the ring size. Towards the end you'll have to nudge the ends so the flats over lap until the "Flats" match up. remove and cut the flats off.
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
09-05-2008, 03:35 PM #15
- Apr 2006
- San Diego
- 375
09-05-2008, 05:07 PM #16
- Apr 2006
- San Diego
- 375
Don't bother. I'll post them myself.
Ed, I don't like you anymore and you're not welcome to S.D.
Funny thing (in a not so funny kind of way) is that I've made countless tables before that required skirts and I always rolled them in one piece. In fact, I was planning on rolling these the exact same way I've always done in the past, which was in one piece. So, I make my own d@mn roller for wider, heavier material and I've lost all my marbles somewhere along the way. I actually took the last six months "off" because of the "accident", and my wife always says I haven't been the same.
Excuse me while I throw this project in to the recylcing bin along with taking a plasma torch to my roller. One person says it should be rolled in two parts, and I'm a lemming.
I've gotta go and do twice the work I should be doing
I'm really mad at myself.Maxstar 200DX
Maxstar 300DX
Passport
Spectrum 701
LMSW-52 spot welder
09-05-2008, 05:08 PM #17
- Apr 2006
- San Diego
- 375
09-05-2008, 05:12 PM #18
Chris-
Sorry wasn't trying say you can roll yer 5" this was- just trying to show the Flat areas that happen when rolling material in these style Rollers.
Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
09-05-2008, 05:14 PM #19
- Apr 2006
- San Diego
- 375
09-05-2008, 05:21 PM #20
Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
