Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
    Apr 2006
    San Diego
    375
    Default Plasma screen stands
    I've been procrastinating long enough and need to knock out eight freestanding supports for some plasma screens to go in some corporate place somewhere.
    Short story is they get a 3/8" thick x 32" diameter steel base, which also gets a 5" x 1/8" skirt. Two 3" OD tubes rise up about 60" and a 1/8" plate gets welded between them to which the factory bracket mounts, and then the screens will hang from that.
    Here's the start:
    1) Eight bases, the template, and the drop. Heavy metal.
    2) Eight mounting plates waiting to bridge the gap.
    3) The bases get bolted to the ground, but they still need to be levelled, so I'm making three adjustable pads for each base, which will get welded to the underside of the disks and be concealed by the skirt. Parts is parts.
    4) My super fancy jig.
    5) Zing-bang.
    Thanks for looking.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Sweet!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Feb 2008
    8
    What does the finished product look like?
    Apr 2006
    San Diego
    375
    Quote Originally Posted by NAS-NAS View Post
    I don't know yet... . Check back in a couple of weeks.
    Once completed, they will get an automotive paint finish.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    bremerton washington
    21
    Default Hey Nice work!!
    That stuff looks great! I only wish I had the refined tecnique you show here!
    I have a Dyn200dx and I love it! I assume that is what you accomplised these weld with!?
    Again,,,good work!!
    MB
    Apr 2006
    San Diego
    375
    Quote Originally Posted by mulugod View Post
    Again,,,good work!!
    MB
    Thanks for the kind words.
    Actually, I used my Passport to weld up those adjustable feet. Quick and easy.
    It's all in the planning, really. Not much to the welding. You'd be surprised.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    Apr 2006
    San Diego
    375
    Default progress
    Here are some progress pictures.
    The skirt/rings are rolled from 1/8" x 5" material. I have to roll them in two halves. Therefore, the halves must be left long, then trimmed to size to fit the base.
    Question: How do you trim the flats off of the rolled halves?
    Answer: I have a shop full of bandsaws, but I'm using a vintage hand shear I picked up for $80.
    The shear rolls the ends a bit (as shears do), so we have to flatten them out with an expensive flattening machine.
    1) Rolled halves. These were rolled on my home-made roller (see other post).
    2) Jigged.
    3) Fancy, expensive cutting tool.
    4) Expensive, complicated flattening machine
    5) Detail of underside.
    Thanks for looking.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    Apr 2006
    San Diego
    375
    Default base
    Picture of the base. There will be eight of these.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    1,880
    If your shear is rolling the edge then the blades are not sharpened or not adjusted correctly. There should be no rolled edge on a sheared plate.
    Apr 2006
    San Diego
    375
    I should clarify. The blades make a clean cut. I wrote that it rolled the edge, which is misleading. The cut is clean, but the plate distorts/curls over the 5" width. This hand shear has a 4" blade, so I have to take the cut in two bites.
    Every shear I've ever used distorts the metal to some degree. Every piece of metal I've had sheared by someone else has been distorted to some degree. This applies to manual, electric, hydraulic, whatever. Every piece of paper I've cut with a pair of scissors has a curl to it.
    When I need to cut something with no distortion, I use a saw... or a water jet.
    On a similar note, I use a drill press (or water jet) to cut holes rather than a punch, which distorts the metal.
    Thanks for looking.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
