I am looking to build a small trailer about the size of a motorcycle trailer. I was wondering if anybody here has built such a trailer and might have pictures. I am just looking for ideas right now. This trailer would be used to haul a couple 80 cu ft bottles of gas, a Dynasty 200, and one or 2 small mig welders and all the associated stuff to go with. The reason for being small is my tow vehicle is a VW Jetta, I know this is an odd combination but it works for the work I am planning on doing.
-Dan
Results 1 to 10 of 12
Thread: Small Trailer Ideas
08-25-2008, 11:39 AM #1
Small Trailer Ideas
Owner
DW Metalworks LLC
Miller Trailblazer 302
Miller 8RC Feeder
Miller Passport Plus
Miller Dynasty 200 DX W/Coolmate 1
Hobart Handler 135
Hypertherm PowerMAX 30
Smith O/A Torch Set
Plus more tools then my wife will ever know about....
08-25-2008, 11:49 AM #2
http://www.carry-ontrailer.com/
Good pics to look at.
I would check to see what a new trailer costs also- the material to build one sometimes costs more than buying a trailer.
08-25-2008, 02:41 PM #3
- Jun 2008
- NORTHERN CALIFORNIA
- 59
small trailer
I just finished a trailer built from an S-10 pickup bed. I built/used these for years...advantages of a pickup without the truck.
08-27-2008, 03:00 PM #4
- Aug 2008
- Appleton WI
- 32
Here you go. I thought I would post up some pics. This is a trailer that I made to get sport bikes to and from the track. Not really to hard to make and it turned out and pulled great.
08-27-2008, 05:23 PM #5
Nice Trailer
Good looking, I presume you use ramps for the cycles.
Miller 140 w A/S
HF 90 Amp Flux Core
Dewalt Chop Saw
Smith O/A Torch
Ryobi, HF grinders
Harley Electra Glide Classic
08-27-2008, 06:19 PM #6
- Aug 2008
- Appleton WI
- 32
Thanks! Yeah we use ramps to get the bikes onto the trailer.
08-27-2008, 06:30 PM #7
Miller Brad, I see one design flaw in your trailer that needs some attention.
Your tongue rail should go back to your second crossmember instead of the first as you have it. Also your diagonals should also go back under the frame as far as the second cross as well. All of the tongue weight forces are on the edge of the front crossmember and will end up bending, kinking or just ripping the tube itself with all of the stress that is being put on it.
Is that a Tor-flex axle on it or is the axle mounted with out springs?
Don't mean to sound critical but building trailers is how I make my living and would rather see you address the problem now instead of when it is too late.
DaveIf necessity is the Mother of Invention, I must be the Father of Desperation!
08-28-2008, 01:17 PM #8
- Aug 2008
- Appleton WI
- 32
08-28-2008, 09:57 PM #9
Miller Brad, That is one fine looking trailer but I concur with dabar 39 on the tongue issue as I've seen the very thing he described happen on a very similarly sized trailer first time out. On that unit the front crossbember was 4" channel and the tongue rolled up to about a 7 degree angle. Solution? The tongue was extended back to the next x-member and the diagonals rearward to the side rails. Result? Rock solid fix. BTW, I wasn't the one that built it.
Beautiful color too! I ssume it matches the bikes?
08-29-2008, 09:11 AM #10
- Aug 2008
- Appleton WI
- 32
Thanks man. It matches the bike of the owner of the trailer, as seen on the far side of this pic. His bike is the Repsol mine is the red one on the other side of his.
BTW: When I say I appreciate the input I really do mean that. If there is a flaw in the design it needs to be rectified.
Didn't mean to hi-jack your thread Dan. Sorry if we got off topic!
