Im thinking about making some new art projects and would like to use some different colors in them. Does anyone know what chemicals will change colors on steel?
Thanks for any help
Results 1 to 10 of 11
08-24-2008, 11:16 AM #1
Chemicals to change colors of steel
Millermatic 175
Miller 375 Extreme Plasma
Cobra Gas Torch
Bosch 14 Chopsaw
08-24-2008, 12:32 PM #2
- Mar 2007
- 132
Blueing or blackening like they do for guns. Blackening is often called black oxide and they do tools as well. Parkerizing is a version for guns I think.
There is an older process called browning they used to do on guns, but I don't know much about it.
Finally, I've heard of people heating the steel red hot and then dipping in used motor oil to get a neat effect.
I guess you know heat will make a neat gold blue purple rainbow effect on shiny steel, but it comes off easily. You might clear coat it.
Other than the above, you're probably looking at plating or paint.
-James
08-24-2008, 03:08 PM #3
- Jun 2007
- arizona
- 105
chemicals
Have you gone to King Architectural and looked at their products? I've used Auburn Rust for a copper/rusting effect but they have others. cat
08-24-2008, 03:10 PM #4
- Jun 2007
- arizona
- 105
Forgot - there's always powder coating with many, many colors. I find the prices not too bad at all for powder coating (in Phoenix anyways). cat
08-24-2008, 03:45 PM #5
- Dec 2007
- National City CA
- 1,086
Here's the deal
Most chemical treatments that are applied to steel to change the color are very expensive to do at home. True Black oxide or gun bluing (same thing just different level of polish to the steel) is very expensive to set up at home.
Five tanks are needed with two of then being heated to a boil (bluing salts boil at 290 degrees F to 310 degrees F) then you need a heated degreaser and two rinse tanks All big enough to drop your part into in one shot. And no other non steel/iron metals can be introduced into the bluing salts or the salt will erupt in a nasty reaction.
Rust browning is a lot safer, simpler, and cheaper, But it takes weeks to perform.
What you are doing is letting the part rust then steel wool the rust off over and over again. This is done in a steam box and with a mild acid compound.
Color case hardening is a heat treatment process and by packing a part in bone chips and chunks the heat is allowed to dissipate from the part at differing rates creating a very beautiful color pattern. Blues, greens, golds, browns, and reds.
Cold blue is safe but not easy the part needs to be completely free of oil I mean when you think you are ready to blue it, it still needs to be degreased
Parkerizing is nearly the same process as Bluing with different chemicals and a slightly different process. just as expensive though.
Then there are the Tin TiAn coatings nice cobalt blue and gold colors but no way you can do this one at home with out some major investment.
All that said cold blue is about the best bet or just let it sit out side to rust.Miller Syncrowave 200 W/Radiator 1A & water cooled torch
Millermatic 252 on the wish list
Bridgeport Mill W/ 2 axis CNC control
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Over 20 years as a Machinist Toolmaker
A TWO CAR garage full of tools and a fridge full of beer
Auto shades are for rookies
www.KLStottlemyer.com
08-24-2008, 05:32 PM #6
Member
- Dec 2006
- Boise, ID
- 34
Spervis,
Try going here http://www.metalartistforum.com/foru...play.php?fid=9 and read all about patinas. You may need to join to do this. The base web address is www.metalartistforum.com.
While there check out the metal work Demo's. There is one on patinas with multiple pictures. This link might work. You'll need to just read and click on the pics as you go. http://www.metalartistforum.com/demo...n04demolog.htm
Good luck.
bob B
08-25-2008, 10:13 PM #7
HI SPERVIS
CHECK OUT THIS SITE , www.sculptnouveau.com , A LOT OF STUFF.
BobbyFABRICATION-CRÉATION K ZEN
MILLERMATIC 210
SPOOLMATE 3035
SYNCROWAVE 200
HYPERTHERM 360
08-26-2008, 05:35 AM #8
- Dec 2007
- alabama
- 715
Last but not least.
www.metallicfinishes.comXMT 350 cc/cv
XMT 350 vs
TRAILBLAZER 302
MILLER DVI
PASSPORT PLUS
DYNASTY 200 DX
MAXSTAR 150 STL
HOBART CHAMP
HF-251 BOX
12-RC SUITCASES
12-VS SUITCASE
08-30-2008, 11:37 AM #9
Member
- Nov 2005
- 86
Metal Changing Color
I have done this for inside art get cold rolled sheets works best but hot rolled works ok if you sand it to a shiny finish then take a small welding tip on torch and heat up areas you want to "BLUE" color will change from silver to brown to blue practice on the amount of time spent too long and you wasted the blueing I have several in my home and they still look good they are BUFFALO SKULLS HORSE HEADS LONG HORNS HORSE SHOES LAMPS ETC
10-31-2008, 10:47 PM #10
- Oct 2008
- 28
rust can be mighty purty......
Esab Multimaster
Esab Migmaster
Miller 251D
Miller Bobcat (old old)
Lincoln Crackerbox
9,000 SF of crap
