I like that and should make one.
Results 11 to 20 of 24
Thread: Homemade press brake
08-26-2008, 03:43 PM #11
- Sep 2005
- 4,248
08-28-2008, 10:55 AM #12
Member
- Feb 2007
- GP, Alberta
- 54
Looks good! I made a similar one using heavy angle, the downside I have found with angle is that the inside corner is rounded so it's hard to get a crisp bend on anything over 3/16
Freelance Fabber
Mobile>
'01 Dodge 1ton w/deck
07 Miller Trailblazer 302g
Miller HF251-d
3hp air compressor
Spectrum 275 Extreme
Shop>
Miller Dynasty 300sd
Lincoln Migpak 180
08-28-2008, 05:10 PM #13
- Apr 2006
- San Diego
- 375
Pretty cool, James.
I also have plans to make press brake when time allows. I have a plan worked out, just need another window of opportunity.Maxstar 200DX
Maxstar 300DX
Passport
Spectrum 701
LMSW-52 spot welder
09-04-2008, 06:23 PM #14
09-10-2008, 08:28 AM #15
I submitted one for the welding challenge. Take a look in the Shop portion of the Welding Projects gallery. Materials list and dimensions are posted there. Saved me hours of work on some handles I needed to make. Well worth the hour it took to put together.
http://www.millerwelds.com/interests...ct/2779494898/
I have since made a second press bar with 1/2" round bar for the edge to create a more gentle radius where desired. Swaps out easily by removing the nuts.
09-10-2008, 10:24 AM #16
What actually operates the down motion?
Can one of these be used with a hydraulic car jack? I'm very new with metal, but know that something like this would be kinda essential...but can't figure out how the pressure is applied
I know, I got a long ways to go
Millermatic 212
1998 Heritage Springer
Kioti DK55
09-10-2008, 11:29 AM #17
- Nov 2005
- 107
09-11-2008, 10:49 AM #18
For those who would prefer a dedicated press brake instead of a press and a brake.
Not my work - pulled down off this site or the Hobart site - but from my files.
I went with a press and a brake myself.
09-12-2008, 06:35 AM #19
12-31-2008, 05:00 PM #20
- Mar 2008
- Midwest
- 109
Metal Brake Complete
JAMSCAL,
I finally built the press brake this PM, except for paint. Successfully bent a piece of 5" x 1/4" flat plate 90 degrees. Bent some thinner .125 stock earlier as a test. Worked fine. My punch is 5" x 17" x 1". I cut it earlier on the track torch, then had my brother in law finish it on his mill. I think maybe the heat on the track torch had it a little wavy. I won't do that again. Bottom plate is 3/8" x17" x 11", spacing on bottom dies is 1 1/2". They are 1" square stock. My press has a 7 1/2" spacing on it and I am wondering if I should put two or three braces across the bottom plate for support. I really was tired of using a vise, hammer and heat.
I think Big Eddy posted a small bench type bender using a 4 ton jack. I think that will work fine for smaller stuff if I do not feel like lugging the break out to the press. He kindly listed plans as well so thats next project.
OBTW, I have $8.00 in my press brake. Two springs and two bolts. I used 3/4" bolts, should have stayed with 5/8". I'll post a pic tomorrow.
Thanks for your post. Lots of great ideas and advice on this site.
