Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Feb 2009
    1
    Default bottom die
    I plan on bending 1/4 steel plate either 3 or 4 inched wide to about 45 degrees. Can I just use solid 1 inch bars for the lower die? What's the spacing if all it will ever do is 3/16 and 1/4? I read somewhere the dies need to be hardened but only for more repeated use. I might even weld in a piece of this ground and polished rod to the upper die for a smoother radius.
  2. #22
    Bend Oregon
    62
    Thats awesome! how much did all the metal cost?
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
  3. #23
    Jun 2010
    1
    has anyone built the mini bender big eddy so kindly posted? I'm interested to see what it can do thickness wise.
    Millermatic 211
    Spoolmate 100
    Lincoln Weld-Pak 100
    Hobart AirForce 400
    Harris D-85
  4. #24
    Aug 2008
    Ireland
    15
    Red face Lower V size
    jdubb bottom die
    The gap between the lower blocks should be approx 8 times the thickness. eg i/4 tk stock should be folded in a block about 2" appart. thats not to say you could not fold slightly thicker plate but doing this increases the chance of cracking and when folding thinner material youl get a bigger radius on the fold than you would like. Best of luck . Hope this helps
