Results 1 to 10 of 12
    Jan 2006
    Eugene, Oregon
    2,428
    Cool A Little 350DX Project
    Got another little project where I was able to utilize the VP function of my 350. These are a couple of longer tubes that go to a helo jack stand I did earlier this year. They use this particular stand for a few different birds and each arm has to be a different length.
    Anywho, material is 6061. The tube is 3/8" where it gets welded and the cap is 1/2" except for the center web. I used a heat gun to pre-heat the parts for about 10 minutes before welding. Only cleaning was a wipe down with denatured alcohol.
    I used a 1/8" tungsten sharpened to a point with a flat ground on the end. I set the machine to independent polarity and used a 100%/70% ratio of EN/EP. Total amperage was 260 wich equated to 281 amps EN to 196 amps EP. You can see the result of this in the last pic. This is a shot of the tungsten after welding both parts. as you can see, it has very little wear after welding at such a high amperage. The other settings were as follows:
    Tig start amps = 60 amps @ 60 ms.
    Gas flow = 18 CFH
    Straight Argon gas
    1/16" 5356 filler
    Hz = 120
    Balance = 75
    Dynasty 350DX
    Dynasty 200DX TigRunner
    MM 350P
    MM Passport Plus
    Spectrum 375 Extreme
    08' Trailblazer 302
    Jan 2008
    Colorado
    673
    Question
    KB:
    Since there is an 'internet obsession' with 'which' tungsten and your paragraph 3 describes (and shows) your tungsten; what color works for you?
    FWIW: I just started TIG class, but they use red or green.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Jan 2006
    Eugene, Oregon
    2,428
    I use 2% lanthanated for both steel and aluminum on my 350.
    Dynasty 350DX
    MM 350P
    MM Passport Plus
    08' Trailblazer 302
    Jan 2008
    Colorado
    673
    KB:
    Thanks, Craig
    Nov 2006
    Lake of the Ozarks MO
    3,447
    Darn nice work...I'd hire yuh
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Jan 2007
    Rosetown, SK.
    514
    Good to here from you KB. Nice work as always & thanks for sharing.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    Oct 2007
    128
    Nice project, good to see you posting your job pics again.
    Jul 2008
    Salem, Oregon, USA
    22
    That is some beautiful work!
    Click on the sig photo
    An Automotive Machine Shop
    Aug 2008
    Thetford VT
    64
    Wink
    Its nice to see quality work.
    Mar 2008
    Baltimore, Maryland
    315
    Nice work and nice machine. One day I'll have all the cool toys.
    James
    Miller Dynasty 200DX SOLD
    WeldTec Water Cooler SOLD
    Miller Millermatic 180 w/ Spoolmate 100
    20Ton press
    And lots of Cut-off and grinding wheels
    www.IAGPERFORMANCE.com
