Results 11 to 12 of 12
    4,248
    total of 4 inches of steel out of position. It does seem that the smaller bits are slower than the larger ones up to a point. It will cut the 3/8 that fast but a guy couldn't do it continuously. I was wondering though from the machinists if there would be better or as good alternative to cutting oil. Lots of difference when it gets to greater thickness, bit gets hotter in deep holes, these holes were inch thick.
    Raymore Missouri
    1,910
    The solid carbide end mill did the job going through the hardened spider gears. I took it easy with .025 each pass to a depth of .375. It was like "butta". Thanks for the info guys.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
