total of 4 inches of steel out of position. It does seem that the smaller bits are slower than the larger ones up to a point. It will cut the 3/8 that fast but a guy couldn't do it continuously. I was wondering though from the machinists if there would be better or as good alternative to cutting oil. Lots of difference when it gets to greater thickness, bit gets hotter in deep holes, these holes were inch thick.
Results 11 to 12 of 12
Thread: OT 2 questions Heli project
08-18-2008, 12:31 PM #11
- Sep 2005
- 4,248
08-31-2008, 05:53 PM #12
The solid carbide end mill did the job going through the hardened spider gears. I took it easy with .025 each pass to a depth of .375. It was like "butta". Thanks for the info guys.
NickNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
