Results 11 to 20 of 24
08-28-2008, 10:55 PM #11
- Mar 2006
- Queens NY
- 1,547
Dynasty 200 DX
Millermatic 175
Spectrum 375
All kinds of Smith OA gear
08-29-2008, 03:59 PM #12
- Sep 2005
- S.W. Pennsylvania
- 2,249
I have the same feeling about the on board generators. It takes energy to make energy, so I don't see how you can benefit from robbing energy for the engine to produce energy for the engine. I've also heard of a plan to use wind turbines mounted on the vehicle to produce the electricity but again you are increasing the drag on the vehicle counteracting any energy gain.
To all who contribute to this board.
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
09-24-2008, 12:12 AM #13
First law of thermodynamics: there is no free lunch. You can never get more energy out than you put in. The best you can hope for is to break even.
Second law of thermodynamics: You CAN'T break even. No process is 100% efficent because heat needs work just to move. Every step you add will decrease the overall efficiency.
And as far as using hydrogen by itself as an internal combustion fuel, it just detonates when ignited. The octane rating of hydrogen is "very low."Equipped with red and blue... and red and green!
09-24-2008, 12:35 AM #14
- Sep 2002
- Clark County, NV
- 2,696
09-24-2008, 03:42 AM #15
- Sep 2005
- WY...armpit of U.S.A.
- 636
Quote by Bodybagger:
Thus the reason for fuel cell/elec. motor technology. Screw the octane and the internal combustion engine it rode in on. Reverse engineering to run an internal combustion engine on hydrogen would be counter-productive when the technology is closing in on commercial success for fuel cell vehicles that will power a vehicle more efficiently without the Rube Goldberg internal combustion engine in the equation.Miller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
09-24-2008, 06:43 AM #16
- Mar 2006
- Queens NY
- 1,547
I've been reading a really good book on Hydrogen. I believe the title is "Hydrogen, hot stuff cool science" It's written as a story but hits many technical points. I just read the chapter on hydrogen as a internal combustion engine fuel. It is possible to use hydrogen but the sucess they have achieved includes direct injection to deal with backfiring and water injection to stop detonation. I think you would be able to convert with water injection only but it doesn't go into extream depth. The nice thing about the book is that it references many articles and sites if you want to investigate further. I'll bring the book to work with me and get the references for the ICE hydrogen stuff and post them.
Dynasty 200 DX
Millermatic 175
Spectrum 375
09-24-2008, 10:23 AM #17
Member
- Jan 2008
- 87
A little off the subject, but have you considered building and tuning it to run on e85. not flex. e85 all the time. E85 has an octane rating of around 100 - 105 and has a lower energy density than gasoline, meaning you need about 30% more fuel. you can safely run something like 13:1 CRs with it though. and it makes a ton more power when you are set up properly.
If your set on hydrogen, then just act like my wife, and ignore me. If you're interested in alternative fuels, check it out.Millermatic 180 Auto Set
09-24-2008, 10:26 AM #18
- Mar 2006
- Queens NY
- 1,547
http://www1.eere.energy.gov/hydrogen...fs/fcm03r0.pdf
took a while to find, the link was old. Haven't read it yetDynasty 200 DX
Millermatic 175
Spectrum 375
09-25-2008, 08:30 PM #19
- Sep 2005
- S.W. Pennsylvania
- 2,249
Thanks a lot for that link. I read about half of it so far, getting tired now, I'll finish it later.
Pureox OA
09-26-2008, 12:50 AM #20
- May 2006
- 176
Getting in on this late but thought I'd add: without plentiful energy (from excess hydrogen production?) to power the pumps and cryogenic processes to compress the hydrogen to a liquid at about 10,000 psi (700 bar), it is unlikely that hydrogen will be available anytime soon in a useful form for automotive purposes. Not to mention the strength required and therefore the weight of a portable tank to contain that kind of pressure for use in an automobile. Not to mention the risk of hydrogen embrittlement of steel lines for moving hydrogen. These problems can be overcome, but not cheaply and not today. See, if you haven't already, http://en.wikipedia.org/wiki/Hydrogen_economy for an in-depth discussion. BTW it is Iceland that is using excess geothermal output to electrically split H20 into H and 02 and compress it for fuel purposes.
Miller XMT-350 CC/CV
Miller S-22A wirefeeder
Bernard 400A "Q" gun
Miller 30-A Spoolmatic w/WC-24
CK 210 & WP-18 GTAW torches
Hypertherm Powermax 30
O/A Rig, Enco 4x6 bandsaw, etc.
