Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    S.W. Pennsylvania
    2,250
    Default Converting gas engine to hydrogen
    My truck engine finally took a dump on me the other day, I think it spun a bearing or something. It started knocking really bad from what seems like the lower end (I have bad hearing) and its loosing oil pressure pretty bad.
    Anyway, since I have to dismantle it if I choose to go the rout of fixing, and I don't use the truck that much, I thought I might try a hydrogen conversion as an experiment. I believe its Greenland where they are using hydrogen on a regular basis dew to the relatively cheap electricity from their hot springs to produce the hydrogen.
    Any help would be appreciated. So far what I can gather is that titanium valves and seats are needed, don't know if thats true or not. As for a carburetor, I've heard that a propane carburetor will work, again I don't know the validity of that and if so, what modifications might be needed.
    Any thoughts?
    The engine is a 502 GM. I also haven't checked on the availability of hydrogen in my area yet.
    To all who contribute to this board.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Mar 2006
    Queens NY
    1,547
    I think hydrogen in an automotive app is usually used in a fuel cell layout (electric). I don't know what you will save by running a gas engine on it. I don't see why it cant be done. I have been looking into hydrogen generators as mileage boosters. I think you need stainless valves as hydrogen embrittlement may be an issue, and the higher levels of moisture in the exhaust may require some slight mods. I have a bunch of books coming, when i get them i'll see if there are any chapters on burning 100% hyd.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    All kinds of Smith OA gear
    Aug 2006
    near rochester NY
    9,881
    Thumbs up
    i been playing with the same idea. i was thinking for a carburetor i would look into rock crawlers or off road specialty supply shops. they have propane conversion carbs for lots of trucks. although many seem to say they are not street legal ??
    might be worth looking into for your carb options.
    seems like i had a set of plans for making hydrogen at home, i'll let ya know if i can dig them up.
    i saw some thing about that on the discovery chanel. they now have a hydrogen production machine the size of a standard coke machine. all you do is feed it city water and electricity and pump out hydrogen to fill the car.
    S.W. Pennsylvania
    2,250
    Quote Originally Posted by Laiky View Post
    Saving money on gas is not really an issue, its more of an experiment. I hardly ever use the truck, but it comes in handy when I need it.
    The reason for the titanium valves as I was told is that the hydrogen burns a lot hotter than gas. The books sound interesting, where did you get them?
    Quote Originally Posted by fun4now View Post
    I have some plans for a home production setup but I'm not really interested in that, at least not at this time. I'll be happy just to get the truck running again. If this all starts to get too complicated, I might just look for a smaller engine to put in it. ( that would be the easiest rout)
    The cokemachine size deal sounds pretty cool. It would be neat to find out how much they cost.
    Pureox OA
    Jun 2007
    San Jose,CA
    43
    I am not sure that it would be practical as a general rule. Internal combustion engines work by compressing air fuel mixture, hydrogen is very hard to compress so compression ratios would need to be lowered. Second, fuel storage and pumping would be an even worse challenge. Alot of auto engines have been converted to run on methane or propane, but hydrogen would be tough. And you thought gas was expensive, wait till you buy 1 lb of hydrogen..... I digress. I would agree with others that state that Hydrogen technology is making use of fuel cells, and although very clean, it is also very expensive.
    John
    John
    Millermatic DVI
    Millermatic 375 xtreme
    And a brand new Syncro 200!!!
    Mar 2006
    Queens NY
    1,547
    Quote Originally Posted by projectwelder View Post
    Care to explain this? I have never heard that hydrogen is hard to compress. Being the least dense element, i would think the opposite is true, unless your reffering to the pump (engine) sealing well enough to compress hydrogen.
    Dynasty 200 DX
    Millermatic 175
    Spectrum 375
    S.W. Pennsylvania
    2,250
    Internal combustion engines work by compressing air fuel mixture, hydrogen is very hard to compress so compression ratios would need to be lowered. Alot of auto engines have been converted to run on methane or propane, but hydrogen would be tough. And you thought gas was expensive, wait till you buy 1 lb of hydrogen..... I digress. I would agree with others that state that Hydrogen technology is making use of fuel cells, and although very clean, it is also very expensive.
    John
    Hydrogen combustion engines are not a new novelty thought. Check out this site for some examples of early hydrogen vehicles. I just found this site and haven't had a chance to really check it out good but this page is quite interesting.
    http://www.hydrogencarsnow.com/hydro...s1807-1986.htm
    Pureox OA
    Apr 2007
    nc
    102
    Quote Originally Posted by burninbriar View Post
    Any thoughts?
    what year truck?? Did you put the 502 in it? I dont remember the 502 coming factory in any chevy truck. the 8.1 was about 495 cubic inches??? just curious by the way...
    hh 187.:
    powcon 300 st
    cheap chinese plasma cutter
    miller diversion :
    S.W. Pennsylvania
    2,250
    Quote Originally Posted by down19992000 View Post
    The year of the truck is anyones guess. Its registered as a 76, but it's a real Johny Cash special. I had a 67 Chevy 1/2 ton that I just wasn't finding the time I needed to do the restoration so when a fellow kept bugging me for it to use as a father son project I agreed if he got me a replacement truck for the farm. Being that it was a father son project I couldn't say no. Its better someone restore it than no restoration and what a good environment for it.
    Anyway, I got this 1 ton 4x4 that I think was a 3/4 ton 2 wheel drive at one time. Nothing on it seems to match, The cab seems to be an 81 with some parts being of an earlier model. The engine, I'm sure is not what belongs in it, its using an electric fuel pump because there is not enough room for the mechanical one.
    There is strong evidence that the truck has been under water and both fuel tanks are bad, I took one off because it had a big hole in the top of it from one of the cab mount bolts and know that I'm finally getting the sludge worked out of the other tank, I noticed its starting to leak a little. I rarely use the truck, that is why I thought it would be a good vehicle to experiment with.
    Pureox OA
    Jul 2008
    Ft Wayne, In
    5
    A couple of guys in our machinists group has been playing around with hydrogen generators and have only improved their mileage on a Toyota Corolla by only 2-3mpg. The drain on the electrical system offsets any improvements from the conversion. The principal involved is to generate sufficient hydrogen via electrolysis and they typically are running 30-40 amps for the hydrogen generator. I personally don't think this is the way to go. Buy a diesel instead.
