Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Jan 2008
    Colorado
    673
    Thumbs up
    Jerónimo:
    Wow, lots of pieces. Nice job, must have taken a lot of time, cutting and fitting. Did you use mig, flux-core or stick?
    How did you stand it up? Edit: AZguy beat me.
    Saddling a dead horse, there's a right way and wrong way to install cable clamps. Sberry's link shows how. Somehow strength is effected, whether you put the u-bolts around the length of the strand or the rolled back stub.
    RETIRED desk jockey.
    Miller Syncrowave 250.
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Quote Originally Posted by Iron Head View Post
    Why? Wouldn’t be because he saddled a dead horse, would it?
    A linesman taught me that trick as well, before that I never paid much attention, now I see them backwards all over... unfortunately!
    Quote Originally Posted by Craig in Denver View Post
    Jerónimo:
    In his first post he mentions that he used his CST 280 with 7018 rods.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Jan 2008
    Colorado
    673
    Quote Originally Posted by c wagner View Post
    C Wagner: thank you, I slept right through that, Craig
  4. #14
    Jul 2008
    Uruguay, small pacific country with south Altantic coasts, 3 million friendly people population.
    91
    Quote Originally Posted by Sberry View Post
    I saw a job today with 2 clamps installed, the mechanic did a nice job and used thimbles nice and tight and installed the clips back wards. As Ironhead said, cant saddle a dead horse, maybe someone has pics from a site with clamping instructions?
    Ok, here is the first google hit. http://wolfadventures.org/Ropes%20Co...rds/clamps.htm Nice tower by the way.
    Thank´s for the link sberry. After your question I started to wonder if the clamps were installed correctly. Well some of them were not. Last night the tower and wind turbine survived 100 kmh wind speeds during a storm, that said, I will return to the farm as soon as possible to reinstall the clamps in the correct way and check the turbine for possible damages to the blades.
    Regards:
    Jerónimo.
  5. #15
    Jul 2008
    91
    Quote Originally Posted by azshadeguy View Post
    How did you stand it up? How did you anchor it?
    Nice job
    Thank´s! First we assembled the tower on the ground, as can be seen in the picture bellow, the base of the tower is a hinge which articulates in line with one diagonal of the suqare formed by the anchors, ie east-west anchors. We selected a level curve on the gorund as flat as possible in a way that the anchor´s eyes and the base bolt where level and all lined together. Then we squared the tower on the ground refered to those east-west vertices. In that way when you rise the tower it is perfectly squared to a horizontal line on the east-west direction, which belongs to a plane that is level. Then installed the east-west cables, not to tight, and with that distance measured, anchored the south cable to the ground plus one meter to compensate the ground slope. Then we took the north cable, aded some more meters of cable for pulling with security (in case somethings fails), and slowly pulled form north with a heavy tractor. The white tube that you see atached to the tower, is a pole used to give more leverage to the pulling cable and to avoid the tractor pulling the entire thing with ground base included.
    Regards:
    Jerónimo.
  6. #16
    Jul 2008
    91
    Craig, total building time was about a week. The hasle was to clean the rod slag of so many spot welds, and to paint the hole thing, which took four more days. I´ve been told that inmersion painting is done by profesional builders of this type of structures, but to bath one side, each at a time would have taken more paint than is was willing to pay for and, even then, internal crosmembers would have required to be painted manually. I was wondering if there is another option to manual or bath painting, perhaps some kind of mobile spray painting tunnel?
    One thing I forgot to mention was the anchors. There are 8 anchors, the inner ones are made from 2" rolled steel angle, reinforced at the tops for hammering. The outer ones are made from 2" scrap tubing I had at hand, all the anchors are 3 feet long. All the anchors are secured by a 4 feet long wood log (used on fences), the logs are buried 4 feet deep and 4 feet far from the anchors. I made 4 tensors for the outside wires, 3.5 feet long, in that way we were able to do the final adjustments of the wires without removing the clamps due to the extra margin of regulation they provide.
    Thank´s!
    Regards:
    Jerónimo.
