Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    4,246
    doesnt need to be precision then, any method, burn it with a torch.
    Aug 2007
    Florida
    39
    Quote Originally Posted by Sberry View Post
    Yeah, I was more concerned about making a pattern to cut it out from than how to cut it. I didn't want an egg shaped hole that I had an inch on one side or the other to fill in.
    4,246
    Even with some guess work you should be able to come close enough to burn it and have it weldable. It would be a big problem if you were to come up an inch off. Heck its so primitive you could hold the thing up there and burn around it till the pipe went thru the hole.
  4. #14
    4,246
    You could even burn the hole smaller and take a Crescent type wrench and flare the hole out for a custom fit.
  5. #15
    Jun 2007
    San Jose,CA
    43
    If you want to layout, fishmouth a section of 3" cardboard tube or cheap 3" vent pipe and use it to trace over the tank.
    John
    John
    Millermatic DVI
    Millermatic 375 xtreme
    And a brand new Syncro 200!!!
  6. #16
    Aug 2007
    Florida
    39
    Lot of good ideas here. I will let you kow what I end up doing and post a pic.
    I almost lost my new welder to the storm here two days ago. Water over the back ditch came up the yard and into my shed. I happened to go out and see my Miller about 1/2" above the water. I managed to get it jacked up. That would have ruined my day.
  7. #17
    Nov 2006
    Lake of the Ozarks MO
    3,446
    Quote Originally Posted by purplewg View Post
    Bummer dude
    It would be nice tho if you would go into your user profile and put in your location so maybe we might know what storm you're even talking about, and while yer at it you could put up you signature and that way we could know what welder you have
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
