Results 1 to 2 of 2
    Default Truck box tie down rails with toolbox
    I just built and installed a pair of tie down rails for my F350 pick up. They were made from 3/16" angle iron with hooks bent from 3/8" round bar. The first 21" back from the cab was fabbed up by notcing out vertical side of the angle iron leaveing 1 3/16" then using the excess cut off a matching section and welded up a box section to set the tool box on. The mounting bolt holes are 1/2" and the hole on the bottom of the box area has a 1 1/8" hole on top to drop the bolt through and put a socket on it.
    Here are some photos,
    MM251
    Synchrowave 200
    PowerMax380
    Century 155GS
    Big Window Elite
    Run silent, run deep
    Jul 2007
    Lancaster, Pa
    431
    Nice job on the rails, thanks for sharing
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
