This winter when everything is slow at work and everywhere else, I plan on starting an enclosed motorcycle trailer for a single bike. I have been looking around on how to construct the sides and roof but so far the only one I found used plywood. I want to keep it lightweight and strong. Has anyone ever done this or have any suggestions, maybe plywood is the best option.
Results 1 to 7 of 7
Thread: Enclosed Trailer
08-10-2008, 06:32 AM #1
Enclosed Trailer
Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
08-10-2008, 06:36 AM #2
Check in your area for a shop that repairs semi trailers and see if they have any roof material or siding from a wreck. I've used this (aluminum) and normally it's great for the price (free at the time). Probably cost you some now though.
08-10-2008, 06:56 AM #3
I think the top might be the hardest to make. How about using a camper shell
for the top. Most have windows and can be found in yards all over town
for sale. The sides should be a lot easier. Since the shell has the flip up rear
door..........the bottom part you make is also the ramp. The sides could be made out of say 1" sq tube for the frame and covered with galvanized
28 gage sheet and pop riveted to the frame with alum rivets. A 4x8' sheet is under $20. Just an idea. I just think plywood looks like crap no matter what you do to it.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
08-10-2008, 12:45 PM #4
- Mar 2008
- Midwest
- 109
Hello,
I do not know if this will help or not, but I just finished an enclosed trailer with a ramp door. I realize it is more than you are planning, but the approach could be scaled for your need. The sides are aluminum panels installed with double sided tape (come prepainted) and the top is a one piece aluminum sheet attached with self tapers and sealing tape. You could scale as appropriate, but it would be considerable more expensive than reusing available used material. Hoops and accessiories can be bought from Redneck or Quality Trailers.
08-12-2008, 08:20 PM #5
Thanks for the replies. They all help in some way.
I did check on damaged semi trailers, the guy that gets them said dont bother, the ones he gets in are in too bad a shape to try and salvage any pieces.
I kinda like Nicks idea about the square tubing and sheet metal. That may be the way I end up going. I have to agree about the plywood, no matter what you do to it, it looks cheap, kind of like paneling from the 60's.Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
2009 FXDC
08-31-2008, 08:58 PM #6
- Jan 2008
- 26
KBar the solution I found while building mine was to cover it with plywood then skin that with aluminum. I used aluminum from Lowes for triming houses it's 2ft x 50ft. It worked out great.I have'nt had time to finish or update the pics yet but I've got the doors framed up and welded and I put a 3500# axle under it and to the outside of the trailer. It weighs 1200# with everything but the doors on it.
08-31-2008, 09:49 PM #7
- Apr 2007
- Colorado
- 35
Rolled roofing
I think this may be my first post here - but I read the forum almost daily. I recently built an enclosed, 7 X 20 trailer and it came out pretty good. I get compliments on it everywhere I take it.
I used (this sounds really Arkansas) galvanized, corrugated roof panels mounted horizontally. I even put the top 6" in a transparent fiberglass, corrugated roofing panel to let in light.
It sounds hokey but it looks good, was cheap, is strudy and watertight.
BUT - my next one is going to be made from steel, pre-finished roofing material - in flat panels and riveted to the angle iron verticals. The steel is available from any rolled roofing manufacturer - and it is very reasonably priced. Let me clarify - the flat steel, before it is run across their dies to form it into roofing panels.
I'll try to take and post a pic - seeing is believing. (it's dark and raining right now)
Good luck!
