weld13,
good luck on that one, looks good![]()
Paint it blue later![]()
Results 61 to 68 of 68
Thread: used stick machine wanted
08-02-2007, 10:55 PM #61
I'm not late...
I'm just on Hawaiian Time
08-03-2007, 08:10 AM #62
08-03-2007, 09:45 AM #63
Well if your goin to check that out let me look again cause there were some others that were ac only for pennies on the dollar. How high do the amps go on the stickmate?
welding...its awsome
08-03-2007, 10:46 AM #64
they go up to 205 amps
Inferno Forge
Chris
08-03-2007, 11:12 AM #65
Aww common keep lookin you gotta need more than 205 amps
my buzz box does 225 and that isn't hardly enuff for me to do what I need
08-03-2007, 12:25 PM #66
give me some more money and i will get more amps
Inferno Forge
Chris
08-10-2007, 09:04 PM #67
- Aug 2007
- New Orleans, LA
- 161
Hate to break it to you boys, but the lincolns you are talking about are 230 volt. I don't think lincoln even builds a 110 volt stick machine. I've used one miller thunderbolt, once, and never again. Miller, Lincoln, Hobart are all good machines, though the Lincoln and Miller have higher duty cycles, and just so you know, Miller owns Hobart. I have always liked Miller shop machines (I've also never burned up anything but a miller, and it was only one, and I toasted it twice, was only six months old, 400 amp machine). I welded for years with a powerkraft (some of the older guys will remember them, aka Monkey-Wards) ac machine when I was learning. It is 40 years old, dad still has it, and still uses it regularly. Never buy a used machine you haven't seen weld, period. If they don't want to let you try it out there is probably a very good reason. I have never used an engine drive Miller that I truly liked not even the '04 Trailblazer a company I worked for had. I did use an engine drive Hobart that was really sweet to weld with, but they don't have the duty cycle I need. My dad's ranger 250 is by far the weldingest (not a real word I know, but ya get the drift) machine I have ever used bar none. The smoothest shop machine I ever used was a Miller Dialarc 250 that had been rebuilt by Lincoln. In fact I would move stuff just so I could get to it with that machine.
08-10-2007, 09:10 PM #68
I belive i will get the hobart stickmate($250,free shipping) ac only but it is new
