Page 9 of 11 FirstFirst ... 4567891011 LastLast
Results 81 to 90 of 105
Thread: Flying Project
  1. #81
    Mpls, MN
    1,790
    I'm curious how you ended up with 4' rotor blades and what calculations did you follow for determining the airfoil's form other than making it look like a wing? How much thrust will the rotors create for your given rpm sweet spot?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
  2. #82
    Raymore Missouri
    1,925
    Quote Originally Posted by Fishy Jim View Post
    Four foot rotors was a guess compared to looking at similar type units and that's the longest my cnc can move in the X axis. The shape of the rotor is based on the 8-H-12 airfoil. Don't know how much thrust yet as that will depend on rotor pitch, speed, rpm, and whether the engine is up to the task.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  3. #83
    Raymore Missouri
    1,925
    Quote Originally Posted by Goodhand View Post
    I'm not following the scary part... just find a test pilot.
    BTW... Do you plan to free fly, once the rotors are attached, or have you considered suspending it between ropes, until you get the feel for it? The problems encountered with learning to fly a device intuitively are not only in controlling the vehicle's attitude, but also in controlling your excitement. Overcorrecting a change in attitude often leads to crashes.
    BTW2... You've done a remarkable job. I share your excitement. Continued success.
    It will be teathered down while running with rotors untill drive train etc prove
    to be ok. Then will try with a little slack.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  4. #84
    Montana, USA
    236
    Not sure I can wait for the video of your first flying attempt... do you mind if I drive over to watch?
  5. #85
    Raymore Missouri
    1,925
    I'm sure you're joking but early testing will be without spectators for safety reasons.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  6. #86
    Montana, USA
    236
    I've got binoculars.
  7. #87
    Raymore Missouri
    1,925
    So.........you're are pulling the old bino ploy? I get it
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  8. #88
    Raymore Missouri
    1,925
    Default Nicks heli short test
    I put the two lower rotor blades on the heli and did a short and limited
    rpm runup. First I noticed some vibration which I need to figure out. The
    centrifigual clutch has a spacer bearing that is like a sprague clutch for lack
    of better description. I'm not quite sure exactly what purpose it served in its
    4 wheeler application. Maybe for engine braking when the throttle was released.
    Anyway I reversed it on installation on the heli so only the clutch shoes would
    drive the rotors and not this bearing upon start up. The problem now is when I
    throttle down the engine which will slow down quickly, the rotors slowing down
    want to drive the engine if that makes any sense. They should free wheel but
    they tend to drive the engine and jerk the rotors and drive train a bit at shut
    down as can be seen in the video. This bearing has to go and I'll have to make a
    spacer bearing to replace this one. So as long as the clutch shoes are not
    expanded, the rotors are totally free of the drive system to rotate.
    Next....with only the lower rotors spinning, the gyro effect(rigidity in space)
    make changing the angle of the rotor head via the handle requiring more effort
    because of this effect. When I shut the engine down, the rotors should free
    wheel to a stop. Maybe the gyro effect will change when all four rotors are on
    and turning. They may cancel out each a bit. We'll see.
    http://www.youtube.com/watch?v=PA-VpL0vAIo
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  9. #89
    Mpls, MN
    1,790
    When you add more rotational mass, it will increase the gyroscopic effect - doesn't matter that they're opposing each other.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
  10. #90
    Raymore Missouri
    1,925
    I realize the more weight and speed, the more gyro effect. I'm talking about a single rotating mass and the 90 degree effect when trying to move it from its plane of rotation. I wonder how the opposite 90 degree effect of the top rotor will effect this.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
