Page 8 of 11 FirstFirst ... 34567891011 LastLast
Results 71 to 80 of 105
Thread: Flying Project
  1. #71
    I haven't read all the posts here but, quick question. Are there pitch horns on the rotors? If not how are you overcoming gyroscopic precession?
    Kenny
    Although aviation has made the world a smaller place, it's still pretty hard to miss when you crash.
  2. #72
    22
    Quote Originally Posted by airsickness View Post
    Kenny
    It's canceled out by each of the counter rotating blades. One blade would experience it but not two.
    Helicopter ATP/CFII A&P
  3. #73
    Jan 2008
    In wal-mart
    460
    Using the 3D program, here are some computer generated rotor blades I have been playing with. If this works, and I can actually make my own blades, it will have paid for the program.
    Your build looks real nice, but take out an insurance policy, and two, wear lots of padding. Something like that can go real bad real quick. Im looking into building a powered parachute which looks pretty crash proof, even if the engine fails. Good Luck!
    If you want peace, be prepared for war!
  4. #74
    Thumbs up
    Monte, it looks as if your well over the hump of committing yourself in this endeavor and do feel that with a good set of testing cycles in mind, success will be forthcoming.
    Good show thus far.
    LW
  5. #75
    Sep 2008
    Omaha, NE
    447
    Man, it's great to see this still going...
    Very nice work Monte!
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
  6. #76
    Raymore Missouri
    1,925
    Default Ultra lite heli updates...
    I just put on 6 photos of my rotor blades nearing completion. Right now they all weigh within a half ounce of each other. I have to glass them and they will need to be rebalanced again. Getting closer!! The photos are in my album on this forum. Click on my profile then view album for those of you who are interested.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  7. #77
    Raymore Missouri
    1,925
    Default Helicopter update video
    I finally got to the point after securing and safety pinning most of the bolts
    and fixtures so that I could safely run the engine, drive shaft and rotor head
    components and see how they worked. No rotors at this time. Here is a Youtube
    video
    Here is the link:
    http://www.youtube.com/watch?v=Do9cElBSWjY
    PS this is starting to get exciting...and scary....
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  8. #78
    741
    Nick,
    Thanks for posting the video, it was great!!!!
    1. How many hours do you have in the project?
    2. Do you know your cost at this point?
    3. What do your neighbors think?
    4. Do all of the parts have to be balanced?
    This project is amazing. To start from scratch and create a "flying machine" is unreal. Please keep us posted.
  9. #79
    Raymore Missouri
    1,925
    Thanks........It was kind of hard to hold the camera and control throttle at the same time so it's not the best video but the real purpose was to show the parts working at the least.
    1.... no idea how many hours but it's a lot since other than engine, hardware, chain, sprockets, clutch etc, I had to make all the other parts with no plans to go by.
    2...I have never figured cost yet...I already had the engine and most aluminum to make the hubs etc. I had to buy sprockets, chain, bearings, clutch and , lots of grade 8 bolts.
    3....neighbors don't really care. We are on three acre lots and I have trees all around.
    4.......All parts should be balanced but that ain't going to happen. Balancing the rotor blades is absolutely a must. I'll just do the best I can.
    I'll keep ya posted.............Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  10. #80
    Montana, USA
    236
    I'm not following the scary part... just find a test pilot.
    BTW... Do you plan to free fly, once the rotors are attached, or have you considered suspending it between ropes, until you get the feel for it? The problems encountered with learning to fly a device intuitively are not only in controlling the vehicle's attitude, but also in controlling your excitement. Overcorrecting a change in attitude often leads to crashes.
    BTW2... You've done a remarkable job. I share your excitement. Continued success.
