I could be wrong here, but I don't think the rotors opposing directions will negate the torque vectors to the point it will be easier to bump the gyros out of plane. The reason airplane engines are canted at 10 degrees off center is due to the torque vector, but that doesn't eliminate the the gyroscopic precession - it merely prevents it from having as large an impact on the aircraft's tendency to yaw because of it.
A way to find out your chances, would be to look up a twin opposing prop airplane and see if the engine is mounted in line with center or skewed. If it's in line, you're in luck. If it's canted, you're probably screwed (or at least going to have a lot of physical effort to fly your machine).![]()
Results 91 to 100 of 105
Thread: Flying Project
11-26-2009, 04:25 PM #91
Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
11-30-2009, 03:10 AM #92
now I thougth I had seen it all.
03-25-2010, 01:42 PM #93
New videos on Monte's heli project
Well now that the weather is warming up some I thought it's time to do more
testing with the heli project. I uploaded 2 new videos of running up the engine
and drive train with all 4 rotors installed. I still have a lot to figure out. This is for the ones that requested updates on my progress.
Nick
http://www.youtube.com/watch?v=SoPOlKnJFwA
http://www.youtube.com/watch?v=-df8RKaa_h8Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
03-25-2010, 05:18 PM #94
Member
- Jan 2010
- Brooklyn, NY
- 73
Wow
I will echo earlier comments and say that is one of the craziest things I've seen on this board. I see you wear a lot of different hats, I didn't think Test Pilot was one of them. Please stay safe.
Matt."A little bit of knowledge is a dangerous thing"
Millermatic 135
Milwaukee 14" Dry Cut Saw
Milwaukee Deep Cut Band
Fully charged fire extinguisher
03-28-2010, 06:55 PM #95
Nick,
Thanks for the videos, they are great. So what is the next test? Did you notice much lift during your test? How much throttle did you use? Keep it up and good luck.
Nick
03-28-2010, 07:03 PM #96
Member
- Dec 2008
- Omaha, Nebraska USA
- 44
Nick,
Can I put a life insurance policy on you? It might pay well with that contraption!!!!
One thing I would do is put a shield on the drive shaft if I was you. You have a lot of trust in your work.
Rick C.
03-28-2010, 11:01 PM #97
- Feb 2010
- Stony Plain, AB
- 11
One of the biggest issues I see is it will not be instinctive to fly with the control system that you are using. Push left to go right, pull back to go forward.
A very ambitious project. Be careful.
03-29-2010, 01:48 AM #98
- Jan 2007
- Montana, USA
- 200
03-29-2010, 06:29 AM #99
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
03-29-2010, 10:52 PM #100
Just wanted to reiiterate (sp?) on what I told you before and what others have said: BE CAREFUL!!! We'd hate to lose you........
I'm not late...
I'm just on Hawaiian Time
