Page 11 of 11 FirstFirst ... 67891011
Results 101 to 105 of 105
Thread: Flying Project
  1. #101
    Nov 2003
    3,627
    Default Contra Rotating Propellers
    Been seeing more and more contra rotating propellers in the radio controlled world and was wondering how your full sized project was coming along.... was also wondering if you might share some pics of the gearbox scheme you used to achieve the contra rotation...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  2. #102
    Aug 2006
    Raymore Missouri
    1,920
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  3. #103
    Nov 2003
    3,627
    OK.... that spider gear setup is a simple elegant solution... Thanks!!
    The mast does look a little lightweight.... know the loading is way different.. but the ones on the Bell Jetrangers and Hughes 500's that I am used to are massive by comparison..... how did you calculate the loading on it??
    My Blue Stuff:
    Millermatic 200
  4. #104
    Aug 2006
    Raymore Missouri
    1,920
    When you say mast, what are you referring to?...The 2" square mast as I call it or the 1" rotor shaft. No calcs were done. Just looked at a lot of other projects and came up with this.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
  5. #105
    Nov 2003
    3,627
    Quote Originally Posted by monte55 View Post
    Monte
    was referring to the "Rotor Mast"
    You may find it useful to refer to Wayne Johnson's text "Helicopter Theory" it is pretty much the standard reference in rotary wing design...
    "Monumental text offers comprehensive, detailed coverage of every aspect of theory and design: elements of vertical flight, forward flight, performance, mathematics of rotating systems, rotary wing dynamics and aerodynamics, aeroelasticity, stability and control, more. Essential reading for those interested in design and development of vertical-flight aircraft. 189 illustrations. 1089 pages
    1980 edition."
    http://books.google.com/books?id=SgZheyNeXJIC
    there are lots of used copies available at reasonable prices...
    My Blue Stuff:
    Millermatic 200
