    May 2008
    NY
    31
    Exclamation How to add a top
    Hi, I had a cheapo plastic cd\dvd\vhstape holder as pictured in the first attachment and decided to weld up a replacement. The 2d and 3d attachment show the result. Unfortunately I stupidly neglected to consider that the height of the tapes go above where I ended the angle iron! http://www.millerwelds.com/resources...milies/eek.gif
    Any suggestions on how to add height and a top before I spray paint this thing? Thanks..
    Joe in NY
    Clarke 131E Arc Welder
    HF 4x6 bandsaw
    Hitachi 4.5" Grinder
    Craftsman Air Compressor
    Feb 2005
    N.E. SD
    1,377
    One of the wonders of steel, is that it will sometimes allow you to hide your sins.
    Add some short peices of anle to the top of what you have and there is your extra height.
    Weld tabs to them and put on wood top.
    Jeff
    May 2008
    NY
    31
    That sounds like a good plan, thanks.
    Joe in NY
    HF 4x6 bandsaw
    May 2008
    San Diego
    180
    Thumbs up
    Steel is the most forgiving! Wish girls were too! You can screw up, weld, grind, heat and bend, paint, and still no one will know!!!!!!!!!!!!!!!!!!!!!!
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
    May 2008
    NY
    31
    Quote Originally Posted by lanceman73 View Post
    I hear you lanceman. Luckily for me my wife is supportive of my hobby welding. I'll post pics when I get this done but I have 3 projects going and need to get more steel to get them done.
    Joe in NY
    HF 4x6 bandsaw
