Just cut out a cardboard template to give to the shop doing the forming. A lot of times plows or dozer blades aren't a perfect radius, especially if worn or bent, so a template will get you very close.
Results 11 to 17 of 17
Thread: Snowplow reface
07-29-2008, 04:35 PM #11
MM250
RCCS-14
07-29-2008, 04:56 PM #12
Millermatic 210
Syncrowave 200
Spectrum 625 X-treme
Hobart Champion 16 W/
Miller 8VS Suitcase
Miller 3035 Spool Gun
Tons of Tools
Microwave
Laptop and Printer
Speakers in the Back for all to hear Sirius Radio!
07-29-2008, 09:38 PM #13
- Sep 2005
- 4,247
No heat, I believe it was 16ga. I used the full sheet to help with muscling it and as I recall had a 4 inch channel or something I clamped along it, I figured out something, as I recall it took an hour or so. If I was going to roll it I would have it slightly undersized so I could spring it back against it, with 16 I could manage , heavier would likely be a problem.
11-16-2008, 10:49 AM #14
Well its almost done. I just need to bolt the cutting edge on when it comes in. I used 14 ga sheetmetal a 2x4 and a hyd jack with a chain wraped around the plow and the metal jacked down using the chain on top of the jack. 3 jacks would have worked better for re adjustment reasons. My arbor press would have been great to use if i had it welded together. Cost was 64 bucks for the sheetmetal and 120 for the cutting edge with shipping and 10 bucks for the paint...Bob
11-16-2008, 04:19 PM #15
11-16-2008, 10:30 PM #16
11-17-2008, 04:48 AM #17
- Sep 2008
- southwestern ohio
- 272
What is the deal with all of the runs in the paint.
