Results 11 to 17 of 17
Thread: Snowplow reface
    1,928
    Just cut out a cardboard template to give to the shop doing the forming. A lot of times plows or dozer blades aren't a perfect radius, especially if worn or bent, so a template will get you very close.
    May 2008
    San Diego
    180
    Did it from a flat sheet, rolled it on in place. Look at the last pic, blow some holes in the angles to let the water drain out.
    How thick was the material and what type of steel? Did you use a torch to heat it? Nice shop, by the way!
    Millermatic 210
    Syncrowave 200
    Spectrum 625 X-treme
    Hobart Champion 16 W/
    Miller 8VS Suitcase
    Miller 3035 Spool Gun
    Tons of Tools
    Microwave
    Laptop and Printer
    Speakers in the Back for all to hear Sirius Radio!
    4,513
    No heat, I believe it was 16ga. I used the full sheet to help with muscling it and as I recall had a 4 inch channel or something I clamped along it, I figured out something, as I recall it took an hour or so. If I was going to roll it I would have it slightly undersized so I could spring it back against it, with 16 I could manage , heavier would likely be a problem.
    3,975
    Well its almost done. I just need to bolt the cutting edge on when it comes in. I used 14 ga sheetmetal a 2x4 and a hyd jack with a chain wraped around the plow and the metal jacked down using the chain on top of the jack. 3 jacks would have worked better for re adjustment reasons. My arbor press would have been great to use if i had it welded together. Cost was 64 bucks for the sheetmetal and 120 for the cutting edge with shipping and 10 bucks for the paint...Bob
    Apr 2006
    TAXACHUSSETTS
    1,515
    4 months later.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    3,975
    Quote Originally Posted by admweld View Post
    4 months later.
    Sure the guy didn't bring it over until a week before the first snow...Bob
    Sep 2008
    southwestern ohio
    272
    What is the deal with all of the runs in the paint.
